Old Proxomitron Forums
May 25, 2013, 04:59:43 AM *
Welcome, Guest. Please login or register.
News: No activity here! This forum is read-only. Go to http://prxbx.com/forums/index.php.
   Home   Help Search Login Register
Pages: [1] 2
  Print
Author Topic: Q: Automatically "press" a button on a form?  (Read 2844 times)
Moshi
Newbie
View Profile WWW Email
« on: November 11, 2001, 02:28:05 PM »
Is there any way for Proxomitron to automatically "press" a button on a form? (example: simulate a click on the submit button for me)
(the form uses POST method and no Javascript)
Thanks
Logged
Administrator
Hero Member
1448105 aflaaten arneflaa
« Reply #1 on: November 11, 2001, 02:51:36 PM »
Can you explain why this would be useful, please?
Logged
Moshi
Newbie
« Reply #2 on: November 13, 2001, 01:49:01 PM »
Right now, I'm using Proxomitron to fill out some form values for me. (eg. login pages, preference pages) And I wanted Proxo to automatically submit it for me each time I visit the page.
(I'm not asking for a new feature, just asking if it's possible as is.)
Logged
Administrator
Hero Member
« Reply #3 on: November 13, 2001, 02:55:10 PM »
Now I get it. I will check around and see if there is one like you ask for, and also try to figure it out myself. Maybe it can be done with javascript - not sure yet.
Logged
Sr. Member
10401286 jor otf jor_otf
« Reply #4 on: November 13, 2001, 05:04:19 PM »
Just a thought...
If you can write a filter that will capture the form name (as in <FORM NAME="myform">), you could use the filter to add this Javascript to the page:
<SCRIPT LANGUAGE="JavaScript"><!--
setTimeout('document.myForm.submit()',5000);
//--></SCRIPT>
Replace 5000 with the number of microseconds you want to have before submittal.
Note: this probably only works in Internet Explorer.
Unfortunately my attempts at writing this filter failed...
EDIT:
if the form does use the name myForm (I found many actually do!), you could use the filter below:
Name = "Form autosubmit - TESTING"
Limit = 1024
Match = "</form>"
Replace = "</form>
<script language="JavaScript"><!--
setTimeout 'document.myForm.submit()',5000);
//--></script>
Feel free to put a better version here
Edited by - Jor on 13 Nov 2001  17:07:40
Logged
Moderator
Sr. Member
« Reply #5 on: March 20, 2002, 10:20:51 PM »
Well you can give the form name manually!
Here is my login filter for the Windows Commander Board:
Name = "WinCom Form Filler"
URL = "home.no.net/wincmd/"
Match = "<form1"
        "name="username"2 name="cookielength" size="7" maxlength="4" value="360"3 name="passwrd"4 name="cookieneverexp" tabindex="4" checked"
        "5</form>"
Replace = "<form name="MyForm"1"
          "name="username" value="myusername"2 name="cookielength" size="7" maxlength="4" value="0"3 name="passwrd" value="mypassword"4 name="cookieneverexp" tabindex="4""
          "5</form>
<!--/setTimeout/--><script language="JavaScript"> setTimeout('document.MyForm.submit()',5000); </script>
          "$STOP()"
I know it's a little late for a reply
Logged
Administrator
Hero Member
« Reply #6 on: March 20, 2002, 10:34:16 PM »
Hi
Cool! It is never too late.
Logged
Bes
Newbie
« Reply #7 on: June 15, 2002, 08:31:27 PM »
Well, When trying this filter on my page, I get a javascript error saying :
Error : Object doesn't support this property or method.
Code : 0
What could be the problem then ?
Logged
Sr. Member
« Reply #8 on: June 15, 2002, 08:32:21 PM »
A few questions...
Which of the filters in this thread are you using?
What browser are you using? (And if using Opera, what is it set to ID as?)
Edited by - Jor on 15 Jun 2002  21:33:22
Logged
Bes
Newbie
« Reply #9 on: June 15, 2002, 08:41:28 PM »
Well, this is the filter I use :
Name = "MoneyBalls - Click MyFavorites"
URL = "moneyballs.com"
Bounds = "<input * >"
Limit = 17240
Match = "<input type="button" value="My favorites" onClick="fillballs()">"
Replace = "<input type="button" value="My favorites" onClick="fillballs()">
          "<script language="JavaScript"> setTimeout('fillballs()',2000);
</script>"
          "<script language="JavaScript"> setTimeout('document.ticket.submit()',5000); </script>
          "$STOP()"
The first part (setTimout ('fillballs......) is working perfectly.
but 5 secs later, when the setTimout ('document.ticket.submit....) part is started, the error pops up.
I'm using IE 6.0
P.S. This is the first line of the form :
<form action="http://moneyballs.com/cgi-bin/lotto/lotto.pl" method="POST" name="ticket" target="_self" onsubmit="return checkpicks()">
Edited by - Bes on 15 Jun 2002  22:03:09
Logged
Sr. Member
« Reply #10 on: June 15, 2002, 09:19:11 PM »
Could you give me a direct link to the page with the form, or post the entire form code? I can't see without live test why it wouldn't work...
Logged
Bes
Newbie
« Reply #11 on: June 15, 2002, 09:36:59 PM »
Hi Jor, to not clutter this thread with my problems, I've sent it by PM
Logged
Sr. Member
« Reply #12 on: June 15, 2002, 10:22:40 PM »
I'm working on this filter, will get back to you if I find what causes it not to work
Logged
Sr. Member
« Reply #13 on: June 16, 2002, 12:29:05 AM »
hi all guys,
here my suggestions.
1. try to write the script out of the form not in it. so a match and replace like:
</script>"
"$STOP()"
could be replaced by:
Match = "<input type="button" value="My favorites" onClick="fillballs()">1</form>"
Replace = "<input type="button" value="My favorites" onClick="fillballs()">1</form>
</script>"
"$STOP()"
note the 1</form> at the end!
as second suggestion, i think you could use also an array to bypass the name of the form, something like document.form[0].submit
i haven't worked on it, this is only what i'm thinking in this moment Smiley
Logged
Sr. Member
« Reply #14 on: June 16, 2002, 12:34:36 AM »
just thinking,
because you know the url, name of the form and the name of the function to be executed, why don't you simply add javascript at <end> without match anything?
Edited by - altosax on 16 Jun 2002  01:35:59
Logged
Pages: [1] 2
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.9 | SMF © 2006-2009, Simple Machines LLC Valid XHTML 1.0! Valid CSS!
