Admin
« on: July 31, 2001, 11:40:49 AM » |
http://arne.jaha.dk/download.php/1,15,5/id34.zipHi all, I came across a site the other day with another tricky way of stopping the right mouse button from working. I suspect this may be an IE "feature". Anyway, here's a filter to fix it. [Patterns] Name = "Allow Right Click 2" Active = TRUE Bounds = "<body*>" Limit = 256 Match = "1oncontextmenu=2" Replace = "1Prx_offcontextmenu=2" Regards, Michael With regards from Admin
Logged
« Reply #1 on: June 08, 2002, 12:35:49 PM » |
A site to test it on is here: http://www.ncsx.org/2002/ncs060302/ncs0603.htmAnd I find that modyfying the orginal filter to this one does the same trick: (new is in red) [Patterns] Name = "Allow right mouse click" Active = TRUE Limit = 256 Match = ".( document.oncontextmenu|onmousedown=|captureEvents()1" Replace = ".PrxOff_1" Best wishes Arne  Imici username: Arne
Logged
Best wishes Arne  Imici username= Arne
« Reply #2 on: June 08, 2002, 12:41:22 PM » |
For those using Paul Rupe's Tame start/end JS: These functions are already nullified in end.js. edit: That doesn't mean Tame JS is the all in one solution for everyone. It can be too restrictive at times, and modifying the scripts is more difficult then switching of a filter  Edited by - sidki3003 on 08 Jun 2002 14:03:35
Logged
« Reply #3 on: June 08, 2002, 01:12:00 PM » |
Yes, I have that filterset here in my default.cfg, but it is turned off. I was sitting here trying to remember why I turned it off in the first place, but could not really remember. When you mention it, I seem to remember that this was the exact reason. It killed a few things I wanted to preserve. But there is much to be learned in Paul's filterset which in fact is really good. So people should download it, try it out and have a look at the good coding in it. Best wishes Arne  Imici username: Arne
Logged
« Reply #4 on: June 08, 2002, 01:35:16 PM » |
I had a hard time with these scripts recently to get some things back e.g. popup bookmarklets, menues depending on timers, and a few more  But finally it worked and it's fun too  Here is Paul Rupe's proxo page again: http://www.geocities.com/u82011729/prox/
Logged
« Reply #5 on: June 08, 2002, 06:28:04 PM » |
hi sidki and arne, this to let you know that in my filter set i have a different approach to tame javascript: i've simply realized 2 tame javascript [vm version] and 2 file, vmstart.js and vmend.js INCLUDING FILTERS in them, not simply js code. this way you can easily recognize what you need and what you can delete. this also allows user to add new code from his own filters. these files also are really simply to maintain. as usual, you can find my filter set at: http://virgolamobile.50megs.com/proxomitron.htmlread also vmstart.txt in html folder. regards, altosax.
Logged
« Reply #6 on: June 08, 2002, 06:55:06 PM » |
Hi altosax, I tried your config recently and liked it  As you saw with the mimefix list (the content-header thread), i adopted some of your ideas. From your vmstart.js i'm using your faked functions idea. So i'm also trying to simplify Paul's scripts, and they look quite different by now  regards, sidki
Logged
« Reply #7 on: June 08, 2002, 06:57:01 PM » |
Nice! Now I have something more to read tonight. I love to read what you guys have made. It gives so many ideas and the opportunity to learn more and to see things I have missed. Thanks! Best wishes Arne  Imici username: Arne
Logged
« Reply #9 on: August 12, 2002, 06:10:22 PM » |
Another filter:
Name = "Allow Right Click 3" Active = FALSE URL = "$TYPE(htm)" Limit = 256 Match = ".(on(contextmenu|mousedown|mouseup)|captureEvents)1" Replace = ".1Prox"
And one question: If i put bounds <script*</script>, the filter dont works well, why?
Note: I changed the replace code. Was missing the point before 1Prox
Edited by - lnminente on 13 Aug 2002 16:08:00
Logged
« Reply #10 on: August 12, 2002, 07:40:04 PM » |
Inminente wrote: quote:
when you use the bounds field, you have to match the whole bounds. this should work:
Match = " .(on(contextmenu|mousedown|mouseup)|captureEvents)12" Replace = " 1Prox2"
but i suggest to not use bounds with this kind of filters because if you use bounds you need also to enable multi filtering, and this increase the time needed to filter the script. if you try to use bounds and not to enable the multi filtering you risk to not filter malicious code contained in the same script, so the filter is well written as it is now.
regards, altosax.
Logged
« Reply #11 on: August 13, 2002, 03:31:38 PM » |
Many thanks Altosax. And sorry, my poor english limit me. I did explain the problem very very bad  I was trying to tell that the filter with Match = " .(on(contextmenu|mousedown|mouseup)|captureEvents)12" only works for the first code matched, but not for the rest. The code to verify it is the next (extracted of http://www.ncsx.org/2002/ncs060302/ncs0603.htm ): <script language=JavaScript> <!-- var message=""; /////////////////////////////////// function clickIE() {if (document.all) {(message);return false;}} function clickNS(e) {if (document.layers||(document.getElementById&&!document.all)) { if (e.which==2||e.which==3) {(message);return false;}}} if (document.layers) {document.captureEvents(Event.MOUSEDOWN);document.onmousedown=clickNS;} else{document.onmouseup=clickNS;document.oncontextmenu=clickIE;} document.oncontextmenu=new Function("return false") // --> </script> Edited by - lnminente on 28 Aug 2002 16:59:25
Logged
« Reply #12 on: August 13, 2002, 06:59:58 PM » |
as i wrote in my first post, if you use bounds with this kind of filter, you need to enable multi filtering, so add:
and the filter will work for all occurrence of the matching code.
regards, altosax.
Logged
« Reply #13 on: August 14, 2002, 12:13:55 AM » |
Sorry, but still doesn't work. With multiple matches allowed, each filter only can match the same code one time. I would like that the same filter matches the same code more times, not only one. Other thing: I don't like the version 3,(without bounds) Why? Because will change this <a href=http:\www.web.captureEvents.cometc.gif>[link]</a> to that <a href=http:\www.web.captureEventsProx.cometc.gif>[link]</a> Perhaps, you can think that there is no web called captureevents.com But i had a problem with the config set of JD5000 with the filter "Browser Info in JS (Browser & OS)" and the web www.onlinedown.net because the filter matches ".online" as a javascript Regards. Edited by - lnminente on 28 Aug 2002 17:02:00
Logged
« Reply #14 on: August 14, 2002, 12:21:21 AM » |
You're right, you need the replacement stack for multiple matches within bounds. I posted an example here .
Logged
