Old Proxomitron Forums
May 24, 2013, 09:13:45 AM *
Welcome, Guest. Please login or register.
News: No activity here! This forum is read-only. Go to http://prxbx.com/forums/index.php.
   Home   Help Search Login Register
Pages: 1 [2]
  Print
Author Topic: Allow right mouse click II  (Read 2257 times)
Sr. Member
View Profile WWW Email
« Reply #15 on: August 14, 2002, 12:27:56 AM »
inminente wrote:
Other thing: I don't like the version 3,(without bounds) Why?
Because will change this
<a href=http:\www.web.captureEvents.cometc.gif>[link]</a>
to that
<a href=http:\www.web.captureEventsProx.cometc.gif>[link]</a>
to make it safer modify it this way:
Name = "Allow Right Click 3"
Match = "document.(on(contextmenu|mousedown|mouseup)|captureEvents)1"
Replace = "document.1Prox"
otherwise you need to write a filter using the # stack.
Logged
Jr. Member
« Reply #16 on: August 14, 2002, 12:36:57 AM »
And If the name of the web is document.captureevents.com ??
Many thanks Altosax and Sidki3003, i think that # is what i was searching.
I have too much to learn of Proxomitron.
Also, JD5000 has in his latest config set one js filter called "Allow Right Mouse Clicks" that works perfectly.
Regards.
Edited by - lnminente on 14 Aug 2002  18:01:02
Logged
Sr. Member
« Reply #17 on: August 14, 2002, 07:14:52 PM »
the best filter i know to allow right click is this one by homeric:
Name = "Allow right mouse click [EAH]"
Limit = 16
Match = "<end>"
Replace = "
<!--//--><script language="JavaScript">
          "if (document.layers)
          "document.releaseEvents(Event.MOUSEDOWN);
          "document.onmousedown=null;
          "window.releaseEvents(Event.MOUSEDOWN);
          "window.onmousedown=null;
          "if (document.all)
          "document.oncontextmenu=null;
          "document.body.oncontextmenu=null;
          "document.body.onmousedown=null;
          "<!--//--></script>
i use this one in my config, but i know the filter use by jd and also appreciate it. otoh, the whole jd config is a well assembled collection of filters, i always download every new release.
Logged
Jr. Member
« Reply #18 on: August 16, 2002, 05:03:36 PM »
Thanks Altosax.
Your knowledge about Proxomitron is great.
Before i was making my own filters set, but now, i'm testing, learning and personifying the JD500 filters set.
Regards.
Edited by - lnminente on 28 Aug 2002  17:09:13
Logged
Jr. Member
« Reply #19 on: August 28, 2002, 04:09:43 PM »
Update 1 for multiple matches (added
 in replace code).
Update 2 for style , dedicated to Altosax.
Name = "Allow Right Mouse Click v.IV"
Bounds = "$NEST(<script,</script*>)"
Limit = 5120
Match = "1.(on(contextmenu|mousedown|mouseup)|captureEvents)2"
Replace = "
1.Prox2"
Other thing, i don't use this filter, i prefer "Allow Right Mouse Clicks" from the config set of JD5000.
I only post here for knowledge of the readers to view the use of multiple matches.
Regards to all.
Edited by - lnminente on 28 Aug 2002  21:49:01
Logged
Sr. Member
« Reply #20 on: August 28, 2002, 06:19:03 PM »
hi inminente,
just a point for style,
not an improvement neither a criticism.
NOTE: this is not a trick of mine, it was suggested by bigpurplemoon time age on yahho prox-list and i've adopted it.
when you have to place some code to discard in a variable you can use the variable for this. this way the filters becomes more readable because you immediately know what stuff will be deleted. also the 0 appears to be the more indicated variable for this.
Logged
Pages: 1 [2]
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.9 | SMF © 2006-2009, Simple Machines LLC Valid XHTML 1.0! Valid CSS!
