Old Proxomitron Forums
May 25, 2013, 04:58:46 PM *
Welcome, Guest. Please login or register.
News: No activity here! This forum is read-only. Go to http://prxbx.com/forums/index.php.
   Home   Help Search Login Register
Pages: [1]
  Print
Author Topic: Image links to Inline  (Read 492 times)
Sr. Member
10401286 jor otf jor_otf
View Profile WWW Email
« on: April 25, 2002, 02:15:48 AM »
Don't think I posted this filter yet:
Name = "Image links to Inline (Not for normal use!)"
Match = "<a href=$AV((*.(jp(e|)g|gif|png)*)1) >2</a>"
Replace = "<img src="1" alt="2"><br />"
It's mainly for use with image galleries, when activated, instead of link after link you will now see all images in-line.
Do not activate this filter for normal webbrowsing!
Logged
Sr. Member
« Reply #1 on: June 03, 2002, 12:17:30 PM »
Current version, this will "get" more images, and also add the link text as an alt attribute. It's been sped up some by using correct bounds.
Bounds = "$NEST(<a,</a>)"
Match = "<a href=$AV((*.(gif|png|jpg|jpeg|jpe|bmp|xbm)*)1) >2</a>"
Replace = "<img src="1" class="image" alt="2"><br />"
Logged
Sr. Member
« Reply #2 on: June 03, 2002, 02:26:04 PM »
because of the use of bounds, this could be safer to take care of something like:
<a target=_blank href="..." alt="...">
Match = "* href=$AV((*.(gif|png|jpg|jpeg|jpe|bmp|xbm)*)1)>2</a>"
also, you don't need <br /> instead of <br>, btw this could help in the next years Wink
Logged
Sr. Member
« Reply #3 on: June 03, 2002, 03:12:13 PM »
Not too sure what you mean with the <br /> comment... I always use XHTML where possible, never encountered any problems
Alterations to the filter are good of course, taken them up. I hadn't really thought this filter through it seems... only found simple links. But you're right they may also use targets.
Logged
Sr. Member
« Reply #4 on: June 04, 2002, 04:58:55 PM »
hi jor,
mine comment was ironic, note the smile at the end Wink
simply, i was saying that xhtml is used by very few sites actually (and probably for a long time) and all the browser still support html. btw, excuse me if mine seemed a criticism.
<added after editing>: <img ... />
best regards,
Edited by - altosax on 04 Jun 2002  18:01:09
Logged
Pages: [1]
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.9 | SMF © 2006-2009, Simple Machines LLC Valid XHTML 1.0! Valid CSS!
