Old Proxomitron Forums
May 25, 2013, 01:23:07 AM *
Welcome, Guest. Please login or register.
News: No activity here! This forum is read-only. Go to http://prxbx.com/forums/index.php.
   Home   Help Search Login Register
Pages: [1]
  Print
Author Topic: SystemCloak  (Read 620 times)
hpguru
Sr. Member
View Profile WWW Email
« on: April 28, 2002, 08:45:56 PM »
Here is a handy freeware security utility to lock your desktop when you step away for a moment. I thought it was nolonger available but I just found it at Sympatico and as luck has it, it was the last version released prior to discontinuation. When run it displays your choice of a screen capture, decoy bitmap, a built-in screensaver or a blank screen. Under Win9x you cannot stop its process via Ctrl-Alt-Del. You can stop its process under Win2k but doing so will leave the taskbar disabled. Really it's not needed under Win2k since it has its own superior desktop lock.
http://downloads.sympatico.ca/tucows/preview/195494.shtml
By the way SystemCloak doesn't replace any system files but there is one dll you may need in order to use it.
msvbvm60.dll
http://www.microsoft.com/downloads/release.asp?ReleaseID=28337
Enjoy!
Logged
Pages: [1]
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.9 | SMF © 2006-2009, Simple Machines LLC Valid XHTML 1.0! Valid CSS!
