Author Topic: Alternative to <start> Filters  (Read 4662 times)
« on: August 15, 2002, 12:28:38 AM »
Lately, when using <start> filters, i came across more and more pages that wouldn't load completely.
So my Bypass Start-End list grew rapidly.
Here is what i use now instead of <start>:
[Blocklists]
List.Bypass_Start-End = "..ListsBypass Start-End.txt"
Name = "Header (top) Multi: Mark start"
URL = "$TYPE(htm)(^$LST(Bypass_Start-End))"
Limit = 128
Match = "<head>"
        "(<html*>)|(<body*>)1"
        "&(^*<head>)"
        "&$SET(2=
</head>
Replace = "
<head>
          "<!-- Start injected  Proxomitron filters Header Top -->
<ProxMarkHdrTop>
          "21$STOP()"
Name = "Header (top) Multi Inject: Tame Javascript (part 1)"
Bounds = "<ProxMarkHdrTop>"
Limit = 32
Match = "*"
Replace = "<script type="text/javascript" src="http://local.ptron/start.js"></script>"
<ProxMarkHdrTop>$STOP()"
Name = "Header (top) Single: Mark end"
Limit = 32
Match = "*"
Replace = "<!-- End   injected  Proxomitron filters Header Top -->"
$STOP()"
Name = "Header (bottom) Multi: Mark start"
Limit = 128
Match = "</head>"
        "((<html*>)&(^*<head>))"
        "(<body)1"
        "&$SET(2=
<head>)"
Replace = "2
          "<!-- Start injected  Proxomitron filters Header Bottom -->
<ProxMarkHdrBottom>
          "</head>
1$STOP()"
Name = "Header (bottom) Multi Inject: DHTML Menu Script"
Bounds = "<ProxMarkHdrBottom>"
Limit = 32
Match = "*"
Replace = "<script type="text/javascript" src="http://local.ptron/menu.js"></script>"
<ProxMarkHdrBottom>$STOP()"
Name = "Header (bottom) Single: Mark end"
Limit = 32
Match = "*"
Replace = "<!-- End   injected  Proxomitron filters Header Bottom -->"
$STOP()"
------------------------- Bypass Start-End.txt -------------------------
#dummy
My Bypass Start-End list is currently empty .
Filters 1 and 4 do the main job. If an essential tag is missing, they create it.
Filters 2 and 5 are just examples.
The top of the header block is where i place most of my start filteres. Start.js *has* to be here, if you use it.
The bottom of the header block is the place of choice for non-essential scripts.
If you want your StyleSheet to override the one of the page author, place it here as well.
Filters 3 and 6 do the clean-up and mark the end.
/sidki
« Reply #1 on: August 17, 2002, 11:06:45 PM »
Hiya sidki,
If I remove the "marking" that filter number 4 makes, then disable filter number 6. Will they still function correctly? Filter number 4 still adds the miising tags, but doesn't put "<!-- Start injected Proxomitron filters Header Bottom -->
<ProxMarkHdrBottom>
« Reply #2 on: August 17, 2002, 11:14:24 PM »
It seems to work, I just want to make sure.
« Reply #3 on: August 17, 2002, 11:19:00 PM »
Hi JD,
Sounds like you want to go for the top of header filters only?
If so, i'd just use filters 1 and 3.
Not 100% sure though, i wrote them a while ago.
Give a shout in case of problems.
/sidki
« Reply #4 on: August 17, 2002, 11:24:33 PM »
So I don't need number 4?
Your still using the <end> filters, right?
Hmmm.. This is a bit complicated to explain...
« Reply #5 on: August 17, 2002, 11:33:44 PM »
I would try it without filter 4 and go to a page without header.
I'm still using <end> filters, i was thinking about replacing them as well ... but thats more complicated:
find the last </html> tag, if there is none create it after ... what?
Edited by - sidki3003 on 18 Aug 2002  00:39:00
« Reply #6 on: August 18, 2002, 12:17:14 AM »
Ok, I'll give it a go. Thx.
LoL
« Reply #7 on: August 18, 2002, 01:33:54 AM »
sidki wrote:
do you think this could work?
Match = "</html>|<end>"
Replace = "</html>"
« Reply #8 on: August 18, 2002, 01:39:27 AM »
I'm afraid no
AFAIK <start>/<end> have to be the only thing in the matching expression.
    • ICQ Messenger - 21893433
« Reply #9 on: September 01, 2002, 11:11:07 AM »
I don't know if it will be usefull for anyone, I have been using a filter for a long time now that will try and fix  the head section so that I at least always have a known pattern and a complete head section to match for in filters which need to inject stuf there...also the main purpose of this filter is to insert a known token, for later filters to match on, so that I could be sure of the order of the injected stuf  (each next inject has to be below the previous inject, and with a possibly absent tag in the head section I could not use e.g. </head>),
and I can't wait until one of you shows me a URL where it'll fail, coz nodoubt this will happen, although I haven't yet come accross a site where it did not work.
It has seen many tweaks in it's lifetime, and it's gotten up to the point that I am not even thinking of trying to explain the logic...(small hint, this is a classic CASE/IF-THEN-ELSE construction)
I'll just say this, it's marked multi so I can use the 'fix'ed tags too for later filters.
To make sure it only triggers at the <start> and not on embedded tags in page-generating scripts, it is STOP()ed when it has done it's job.
Name = "Fix: HEAD section insert PING (JarC) [multi]"
URL = "*&(^$IHDR(Content-Type:*PrxOriginalType*))&$TYPE(htm)"
Limit = 4096
Match = "<"
        "(HTML>9(<HEAD             $SET(1=9)"
        "          |</HEAD            $SET(1=9
8
</HEAD>)"
        "          |<TITLE>8</TITLE  $SET(1=9
<TITLE>8</TITLE>) $SET(2=</HEAD>)"
        "          |</TITLE           $SET(1=<TITLE>9</TITLE>)       $SET(2=</HEAD>)"
        "          |<BODY8           $SET(1=9
</HEAD>)           $SET(2=<BODY8>)"
        "|HEAD>9(<TITLE>8</TITLE    $SET(1=9
<TITLE>8</TITLE>)"
        "        |</TITLE             $SET(1=<TITLE>9</TITLE>)"
        "        |</HEAD              $SET(1=9
</HEAD>)"
        "        |<BODY8             $SET(1=9
        "|/HEAD                       $SET(1=</HEAD>)"
        "|TITLE>9</TITLE             $SET(1=<TITLE>9</TITLE>)       $SET(2=</HEAD>)"
        "|/TITLE                      $SET(1=<TITLE>Untitled</TITLE>) $SET(2=</HEAD>)"
        "|BODY8                      $SET(1=</HEAD>)                 $SET(2=<BODY8>)"
        "$STOP()"
Replace = "
 <HTML>"
 <!-- Original Location: u -->"
 <HEAD>"
 <!-- PING! -->"
 1
2
Edited by - TEggHead on 01 Sep 2002  12:20:33
« Reply #10 on: September 01, 2002, 11:33:56 AM »
a new filter to try.
now i understand also your question about <!--ping -->
<edit>:
what the 8 variable do in this line?
"          |</HEAD            $SET(1=9
8
</HEAD>)"
Edited by - altosax on 01 Sep 2002  13:56:03
« Reply #11 on: September 02, 2002, 12:03:49 AM »
: now i understand also your question about <!--ping -->
<edit>:
"          |</HEAD            $SET(1=9
8
</HEAD>)"
beats me...probably a leftover from a previous edit...seems as if it can be snuffed without risk...
