JSProperties.ptxt bug
Jul. 19, 2011, 03:42 AM
http://forum.proxcn.info/viewtopic.php?f=3&t=394
Am I the only one seeing a Proxomitron syntax error dialog at http://fxtrade.oanda.com/analysis/forex-order-book ? You may have to open the Proxomitron's main dialog to see the error dialog. syntaxerror.png (Size: 10.5 KB / Downloads: 1014)
JSProperties.ptxt contains Code: ## ||||||||||||||||||||||||||||||||| Exploits |||||||||||||||||||||||||||||||||The Match of "Block/Modify: Sel. JS Properties" and "<a>...: Block sel. JS Properties" contains "\3". The Replace of "Block/Modify: Sel. JS Properties" and "<a>...: Block sel. JS Properties" contains "\0". It looks like \3 may capture strings that cause problems when "$SET(0" executes $ADDLST. For now, I'm changing \3 to $WESC(\3). JSProperties.ptxt (Size: 5.06 KB / Downloads: 1025)
This will make the Log-Rare entries look ugly, however. Code: WEB JS_Prop .fromCharCode\(g.charCodeAt\(h\)^f\[\(f\[d\]\+f\[b\]\)%256\]\) http://fxtrade.oanda.com/wandacache/ob-06a465144feb1de7a4850186d2dc70902306fa21.jsFilters in question Code: [Patterns] |
Jul. 19, 2011, 09:36 AM
RE: JSProperties.ptxt bug
(Jul. 19, 2011 03:42 AM)JJoe Wrote: Am I the only one seeing a Proxomitron syntax error dialog at http://fxtrade.oanda.com/analysis/forex-order-book ? I didn't see that syntax error dialog with Proxomitron's main dialog opened. It does was caught into Log-Rare without causing any problems: Code: WEB JS_Prop .fromCharCode(g.charCodeAt(h)^f[(f[d]+f[b])%256]) http://fxtrade.oanda.com/wandacache/ob-06a465144feb1de7a4850186d2dc70902306fa21.js |
Jul. 21, 2011, 05:25 AM
I also get the same Log-Rare entry with no error message.
