RapidShare (moved into "Website Customization")...
Mar. 04, 2012, 12:25 PM
RE: RapidShare (renamed from "proxcerts/certs")...
odd... still not working for me...
IE8, WinXP... but i also tested in Opera 11.61, build 1250, Win32, WinXP - didn't work there either... and also tested in Pale Moon 3.6.30, essentially the same as Firefox 3.6 - didn't work there either... hmm, perhaps it's a WinXP issue? i'll tweak around with the "test5", WinXP must be sent different code, that's all i can figure, the two IF's are not being removed... the code RapidShare is sending me is Code: var bStartPage = true;//auf https wechselnso it seems they are sending me "commented code" and sending you uncommented code... |
Mar. 04, 2012, 12:50 PM
changed "test5" to this
Code: Name = "RapidShare: Preserve Half-SSL - Part 5 (mod)"![]() since they're sending us different code (WinXP? Geolocation?), i've attached the bypassed source code, maybe that will help
Mar. 04, 2012, 02:23 PM
(Mar. 04, 2012 12:25 PM)ProxRocks Wrote: so it seems they are sending me "commented code" and sending you uncommented code... No. I see commented code but "<script><style> Remove: Comments 09.07.04 (multi) [jd sd] (d.r)" removes the comments and allows my filter to match. Have you disabled "<script><style> Remove: Comments 09.07.04 (multi) [jd sd] (d.r)"? |
Mar. 04, 2012, 03:10 PM
i have that "required" filter ENABLED - but it isn't matching those "comments"...
now i'm really confused
Mar. 04, 2012, 03:21 PM
when i revert to the "untouched" RC1, the comment filter is matching...
there "shouldn't" be any additions/subtractions from my "everyday config" that caused the comment filter to no longer match, but alas "something" has... looks like i have some digging to do on this end... i'll keep you posted of anything i find... |
Mar. 04, 2012, 09:18 PM
(This post was last modified: Mar. 04, 2012 09:51 PM by ProxRocks.)
here's what is happening...
take the RC1 config and make ONE change, ONLY ONE, and the "<script><style> Remove: Comments 09.07.04 (multi) [jd sd] (d.r)" will NO LONGER "remove comments"... that ONE change - DISALBE "7.3 Block specific Third Party Scripts" and ENABLE "7.1 Block all Scripts" instead... where's that lead us? this seems to be a "bug"... "7.1" seems to be making the rest of the config NOT function as intended... "7.3" seems to work, as does "7.2"... edit: nevermind... still "tracking it down"... |
Mar. 04, 2012, 09:28 PM
(This post was last modified: Mar. 04, 2012 09:50 PM by ProxRocks.)
JJoe,
"sidetracking" temporarily... i think the problem digs deeper than "RapidShare" - posting a new thread (RS - Prox Menu/Debug)... edit: nevermind, still "tracking it down"... |
Mar. 04, 2012, 09:56 PM
the one thing i DO KNOW with 100% certainty - take the RC1 config and set it from default "7.3 Block specific Third Party Scripts" to "7.1 Block all Scripts" and it will NO LONGER "remove comments"...
so i do suspect that a "bug" has been found... is this what you're seeing, JJoe? |
Mar. 04, 2012, 10:58 PM
(Mar. 04, 2012 09:56 PM)ProxRocks Wrote: the one thing i DO KNOW with 100% certainty - take the RC1 config and set it from default "7.3 Block specific Third Party Scripts" to "7.1 Block all Scripts" and it will NO LONGER "remove comments"... Yes but that is expected. "7.1 Block all Scripts" matches first and hides the code that would trigger "<script><style> Remove: Comments". No bug. Doesn't Rapidshare require javascript? BTW. Does Rapidshare work in IE8 without our Rapidshare filters? |
Mar. 04, 2012, 11:16 PM
(This post was last modified: Mar. 04, 2012 11:55 PM by ProxRocks.)
(Mar. 04, 2012 10:58 PM)JJoe Wrote: Yes but that is expected. "7.1 Block all Scripts" matches first and hides the code that would trigger "<script><style> Remove: Comments". No bug. 1) ah, "7.1" matches first, no bug - makes sense... 2) does RS req JS - yes and no... i use $SET(sAdKey=...) within Exc-U to axe out the "un-needed"... so while a site will require JS via $SET(0=i_script:0.), i don't allow "twenty" scripts if the site functions with "two"... but to "test" filters, i disable "2 Scan User List - Append to Keywords", so the site functions "as intended", so to speak... 3) does RS work in IE8 without our RS filters - no, not in Half-SSL... sure, an Exc-U entry could disable Half-SSL for RS as a "last ditch, i give up" route, lol... i guess the underlying goal is to achieve Half-SSL on RS... (which i belive i stated at the start, but would have to re-read to check, lol...) [edit: but does work with our RS filters, but not "100%", the famed ol' "SSL nag crap" rears its ugly head - i really REALLY wish there was an OS-Level way of NOT checking "certificates", 'at MY own risk'] |
Mar. 05, 2012, 12:24 AM
(This post was last modified: Mar. 05, 2012 01:07 AM by ProxRocks.)
Eureka! I think I found the Half-SSL nag culprit!
Will report back shortly if I can verify it more accurately... edit: did have to alter my Exc-U entry from [^/]++.rapidshare.com/ to ([^/]++.|)rapidshare.com/ (ie, the i_script:0 was no longer catching, which was the 7.3 vs 7.1 thingy, the previous used to be sufficient, but now RS "bounces" back and forth more than it did a week or so ago between more of its own sites before the dowload button shows up) |
Mar. 05, 2012, 01:54 AM
(Mar. 05, 2012 12:24 AM)ProxRocks Wrote: edit: did have to alter my Exc-U entry from [^/]++.rapidshare.com/ to ([^/]++.|)rapidshare.com/ Did you update all the old filters? I had to change the URL match in the "rapidshare.com test3". In the future, I'll try to add dates or version to all posted filters. |
Mar. 05, 2012, 02:10 AM
Post: #28
good catch! i just updated that portion of the "CDownloadManager" filter...
that "appears" to be the last nail in the coffin... i'll post "all" of the 'final RS' filters once i test them a little more - i've made several changes and have several versions of each filter, i've been testing various combinations of each until i get NO SSL NAG "CRAP"
Mar. 05, 2012, 02:23 AM
Post: #29
| RE: RapidShare (renamed from "proxcerts/certs")... | |||
Mar. 05, 2012, 02:56 AM
(This post was last modified: Mar. 05, 2012 03:00 AM by ProxRocks.)
Post: #30
for those following along, lol -
here's where my RapidShare filters sit, seem to work just fine... note: only tested in GreenBrowser (IE8) and only tested in Half-SSL and advanced mode with "7.1 Block all Scripts" enabled... with the config blocking scripts, you need to allow scripts in Exc-U for RapidShare to "function"... i still block a here is my Exc-U entry: Code: # RapidShareHeader Filter: Code: In = FALSEWeb Page Filters: Code: Name = "RapidShare: Preserve Half-SSL - Part 2"i don't know if Part 5 and Part 6 are "needed" or not... they block out portions of a script that don't seem to be needed, downloads work without the portions that these two filters block... also, there "was" a filter that matched for ":location" and replaced with ":location" - i'm not currently using it and yet everything seems fine... |
