google my ip
May. 24, 2013, 06:23 PM
google my ip
Using sidki I can't see my ip when I search google for "my ip", is there some filter I need to update?
It works when bypassing. |
May. 24, 2013, 09:34 PM
RE: google my ip
Works for me. What country, language, and browser should I use to try to replicate the problem?
Can you find the info in this page, http://www.google.com/search?q=my+ip&com...and=dbug.. ? For me it is in <li class="g tpo knavi obcontainer" . If you can, is there a filter matching it and not putting it back? |
May. 25, 2013, 05:41 AM
(This post was last modified: May. 25, 2013 05:41 AM by mono3.)
RE: google my ip
I think it was due to an outgoing header filter I added to change the user-agent when accessing google. If I remember correctly I read on this forum that it could be used to disable autocomplete or some other google "feature" that I didn't want. But as a side-effect when the user-agent is empty google doesn't display the ip.
May. 26, 2013, 02:28 AM
RE: google my ip
Thanks for info.
