prox-config-sidki_2019-01-26b1
Feb. 15, 2022, 11:18 AM
Post: #76
RE: prox-config-sidki_2019-01-26b1
(Feb. 15, 2022 05:20 AM)JJoe Wrote:  Anyway, make sure
Key = "Server: Cloudflare 22.02.06     [jjoe] (d.0) (In) [add]`"
Match = "cloudflare &$RESP(403 Forbidden)&$SET(keyword=.a_jsprop.i_loc_j:0.a_jsmeth.)(^)"
is in place, that the server is cloudflare, and the response is 403 Forbidden.
Header filter is in place, server is cloudfare, response is 403 Forbidden
(Feb. 15, 2022 05:20 AM)JJoe Wrote:  The headers should be at the top of the page.
If the headers are there, check the page and verify an absence of
<Match: Block/Modify: Sel. JS Properties 07.04.02 [sd] (d.2) >
and
<Match: Block/Modify: Sel. JS Methods 10.09.07 [sd] (d.r) >
There are none of those two matches.
Feb. 15, 2022, 11:33 AM (This post was last modified: Feb. 15, 2022 11:36 AM by ProxRocks.)
Post: #77
See attached.
.png  2022-02-15_6-21-12.png (Size: 401.38 KB / Downloads: 279)
.png  2022-02-15_6-28-18.png (Size: 164.32 KB / Downloads: 274)
.png  2022-02-15_6-31-13.png (Size: 29.92 KB / Downloads: 281)
.png  2022-02-15_6-35-37.png (Size: 19.2 KB / Downloads: 280)
Feb. 16, 2022, 04:24 AM
Post: #78
Sometimes I have to solve 4 captchas but you don't seem to be getting that far.
(Feb. 15, 2022 11:33 AM)ProxRocks Wrote:  2022-02-15_6-31-13.png
I wonder. Sometimes, instead of the captcha, I will see
Quote:This is taking longer than expected, check your Internet connection and reload the page if the problem persists.
or 'Some file was accidentally cached... Please reload.'
Maybe you are see the problem without the alert and just need fresh files.
Opera hasn't always refreshed cached files as expected. When I suspect this, I open DevTools to the Network tab, enable "Disable cache", and load the page with DevTools open.
I don't know if 360Chrome has this problem but it does have a "Disable cache" setting on its DevTools Network tab.
You could also try adding
newassets.hcaptcha.com/c/&*/hsw.js $SET(0=a_jsprop.a_adfn2.)
to the other hcaptcha entries in Exceptions-U.
Feb. 16, 2022, 10:31 AM
Post: #79
No change, still same results as before any of the suggested changes.
Feb. 17, 2022, 12:31 AM
Post: #80
Lets see if there is anything we can do.
The attached CloudflairTest.cfg only modifies the Accept-encoding header.
Can you access the site with it?
(Feb. 16, 2022 10:31 AM)ProxRocks Wrote:  No change, still same results as before any of the suggested changes.
.zip  CloudflairTest.zip (Size: 5.32 KB / Downloads: 261)
Feb. 17, 2022, 01:59 AM (This post was last modified: Feb. 17, 2022 04:57 AM by ProxRocks.)
Post: #81
(Feb. 17, 2022 12:31 AM)JJoe Wrote:  Lets see if there is anything we can do.
Yes, I can access the site with that test config.
Feb. 17, 2022, 05:00 AM
Post: #82
(Feb. 17, 2022 01:59 AM)ProxRocks Wrote:  Eureka! That works!
I noticed that the BypassURL, SslCiphers, and MaxCapURL lines are different than in the 2019-01-26b1 config - which entries are preferred for everyday use?
Glad it works because it implies that we should be able to 'fix' the 2019-01-26b1 config.
Add a filter that will visibly modify the page, so we can be sure the Proxomitron is actually in the middle.
That cfg is probably not one you want to use. It is a modified version of Scott's default cfg for the Proxomitron with almost all of the filters disabled.
We can't use the BypassURL with 2019-01-26b1.
The MaxCapURL entry is personal choice. I like to see more lines at http://local.ptron/.pinfo/urls/
I changed SslCiphers to use the 'strongest' available. Hoping that it would help at Cloudflare. But, if you didn't start the Proxomitron with a cfg that used that line, you may not have been using those ciphers.
Now we have to find what it is about 2019-01-26b1 that hangs the page for you but not me...
Did you start the Proxomitron with the Cloudflare cfg?
Feb. 17, 2022, 05:56 AM
Post: #83
(Feb. 17, 2022 05:00 AM)JJoe Wrote:  Did you start the Proxomitron with the Cloudflare cfg?
No. Started it with my default (based on 2019-01-26b1 with uNorm). Then used the systray context menu to load the test config.
Feb. 17, 2022, 11:06 AM
Post: #84
(Feb. 17, 2022 05:00 AM)JJoe Wrote:  That cfg is probably not one you want to use. It is a modified version of Scott's default cfg for the Proxomitron with almost all of the filters disabled.
Ah yes, I see that now. I didn't look that deep the first pass, just knew it worked for those Cloudfare captchas.
Feb. 17, 2022, 07:40 PM (This post was last modified: Feb. 18, 2022 12:13 AM by ProxRocks.)
Post: #85
I would be interested in a filter that sets any javascript timer that exceeds a preset limit (8 minutes?) converted to hours instead.
If the timer kicks in at 8 minutes, make it 8 hours instead.
If the timer kicks in at 14 minutes, make it 14 hours instead.
Normally, I can rely on the "timer" button that sidki's config places in the lower left corner but this particular web site will not function unless I set a_jsmeth.a_jsprop. in Exceptions-U.
End-in-mind, I don't want any of my web sites automatically logging me out just because that web site thinks I'm "idle".
I'm not "idle", I simply have that web site on monitor #5 and I'm working on monitor #1 while reading monitor #5 but not "doing anything" on monitor #5.
edit - another route perhaps, can we force all "requestIdleCallback" functions to always return 10 seconds so that the web site thinks I'm not "idle"? Maybe even "requestAnimationFrame" and "queueMicrotask"?
Feb. 18, 2022, 02:31 AM
Post: #86
(Feb. 17, 2022 11:06 AM)ProxRocks Wrote:  just knew it worked for those Cloudfare captchas.
But you did have to solve the captchas to reach the site?
(Feb. 17, 2022 05:56 AM)ProxRocks Wrote:  No. Started it with my default (based on 2019-01-26b1 with uNorm). Then used the systray context menu to load the test config.
So it is probably not the ciphers...
Does this filter
Name = "Remove logo"
URL = "raybuck.com/firebird-vs-trans-am-history-trivia/"
Match = "<div class=$AV(logo-tagline-container)*</a> </div>$STOP()"
Replace = "It's gone"
remove the Raybuck auto body parts logo and parts search box at the top of https://raybuck.com/firebird-vs-trans-am-history-trivia/?
Feb. 18, 2022, 03:43 AM
Post: #87
(Feb. 18, 2022 02:31 AM)JJoe Wrote:  But you did have to solve the captchas to reach the site?
Yep, had to solve the captcha (twice).
Feb. 18, 2022, 03:53 AM
Post: #88
(Feb. 18, 2022 02:31 AM)JJoe Wrote:  Does this filter
Yes. Only in the CloudfairTest.cfg (as I cannot load raybuck.com in anything but it).
.png  2022-02-17_22-50-25.png (Size: 37.69 KB / Downloads: 283)
Feb. 18, 2022, 02:21 PM (This post was last modified: Feb. 18, 2022 02:33 PM by ProxRocks.)
Post: #89
Hope I'm not asking too many questions.
Quickly discovering I didn't learn as much about sidki's set as I thought I did way back when Sad
This one should be easy.
I have a test-case filter to nullify "idle".
Works for what I need it to do and haven't bumped into any ill side efects (well, some, but not adverse enough yet, I can easily add a flag to limit which sites it gets used on).
But how do I have it add to any of the "Display Information" flyovers that are displayed in the lower left corner?
Name = "Nullify Idle    22.02.18 [pfr] [add++]"
URL = "$TYPE(js)"
Limit = 4
Match = "Idle"
Replace = "null"
Feb. 19, 2022, 01:24 AM
Post: #90
JJoe - what are your Exceptions-U entries for Google?
I'm unable to get Google Sheets / Docs / Voice / Gmail / Drive to log in while using Proxomitron.
