sidki's config set: 2005-06-09
Jan. 18, 2005, 07:48 AM
Post: #61
Been wondering about this since IE. Probably a dumb question.
"Add: Time to Title, Snip Excess {3}" also adds the time when you use "Create Shortcut" from the browser context menu. Is there any way to have the shortcut ignore the date? |
Jan. 18, 2005, 02:24 PM
Post: #62
No. You're confusing configs btw.
Jan. 20, 2005, 06:03 AM
Post: #63
sidki Wrote:No. You're confusing configs btw. Oops -_- Of course I meant "<title>: Add Time - Fix Tag - Snip Excess 4.11.24 (multi) [jd sd] (d.1)." Was playing with both cfgs. I have another question. Don't know if it applies to Prox, Firefox, or both. It's just happens to be another one of those pages that require registration. I have no problem with this sites home page, but I cannot debug this particular page, & I can only "view page source" from the FF shell menu, not from the Prox Menu. http://tvlistings.zap2it.com/grid.asp?pa...d=national Results of selecting "dbug" Or "src" from Prox Menu, or manually adding xdbug.. to location: Code: HTTP/1.1 302 Object movedSame goes for both your cfg & JD alpha (only difference: with JD Alpha, Cache-control: private) Everything works normally when using IE, although your Prox Menu does not appear in IE for me, so I had to apply the debug manually. I tried it in numerous combinations, including the basic Prox default cfg, my current customized FF setup, & a fresh, unadulterated FF install, both on C:\ & H:\, with registry adjusted for both. Is this just one of those case where, unlike IE, FF won't display certain pages, or is something else going on? |
Jan. 20, 2005, 02:44 PM
Post: #64
Yeah, that happens - not always - if a page requires a cookie in order to show up.
Firefox - but not IE - doesn't send the ID cookie for this page if the hostname doesn't match exactly (because of the URL command). This is the correct behavior. What works in such cases is right-clicking in Proxomitron's log window, selecting "HTML Debug info", and reloading the page (without URL command). Regarding zap2it, there was a specific question and a comprehensive answer by ScoJo at prox-list a while back: Quote:The browser is not sending the cookies because it thinks the server'sNote that the quoted filter is a bit controversal imo, as it sends *every* hostname specific cookie to all subdomains of that host, no matter if in source- or normal view. You'd need to clear your cookies first if you want to try it anyway. Regarding the Prox menu, it does appear there for me with IE. Sometimes IE forgets to load a script, try reloading the page. sidki |
Jan. 20, 2005, 07:07 PM
Post: #65
nolan;
(I tried to post this last night, but right in the middle of the act, the server went TU on me. [angry] [angry] [angry] ) I see from the snippet of your log file that you are getting a 302 response code. According to the W3C, that translates to: "The requested page has been temporarily moved. The server will automatically redirect you to the new location." From that, I must deduce that your FF/Proxo combination is not allowing the redirect to take place, whereas it would appear that IE is faithfully executing that redirect. So, should we suspect that your FF/Proxo combination is disallowing redirects, but not your IE-centric config? Oddysey I'm no longer in the rat race - the rats won't have me! |
Jan. 21, 2005, 07:12 AM
Post: #66
Oddysey Wrote:I tried to post this last night, but right in the middle of the act, the server went TU on me.Yeah. Lately, before hitting the forum bookmark. I cross my fingers a kiss a rabbits foot. Thanks for trying. sidki Wrote:What works in such cases is right-clicking in Proxomitron's log window, selecting "HTML Debug info", and reloading the page (without URL command).Forgot all about that. Never occurred to me [blush]. Hint: Instead of reloading the page, one may also right click a shortcut to the page & select "open in new window." sidki Wrote:Regarding zap2it, there was a specific question and a comprehensive answer by ScoJo at prox-list a while back:Both the log window & header filter methods work fine. ![]() sidki Wrote:Note that the quoted filter is a bit controversal imoHow might this be problematic? Just wondering. I've already made it site specific. |
Jan. 21, 2005, 10:25 PM
Post: #67
nolan_vode Wrote:Well, just read/post the entire quote and you'll know.sidki Wrote:Note that the quoted filter is a bit controversal imoHow might this be problematic? Just wondering. I've already made it site specific. ![]() Say you log in to that.site.com and your personal data are stored in a cookie, which is restricted to that very host - sometimes for a reason. Now, if you go to this.that.site.com with that filter - as posted - activated, the data cookie would be sent to this host as well. Anyway, i think i found a solution to this, without messing with the cookie domain field - as long as you use the commands from the Prox menu. It required a couple of changes, so it will be in the next version, which i will upload as soon as i can motivate myself to write this darn config control doc. ![]() sidki |
Jan. 22, 2005, 01:35 AM
Post: #68
O.K.....I get it .
Thanks ~nolan
Jan. 23, 2005, 02:18 AM
Post: #69
Hey sidki,
Great config 28-12-2004, as usual. Thanks for sharing your work and keeping Proxo "up-to-date". I saw these two header filters and was wondering if they are a duplication [HTTP headers] In = TRUE Out = FALSE Key = "Expires: Kill: Cache!/Fresh! 4.12.23 (cch!) [srl] (d.0) (In)" URL = "(^$KEYCHK(^S))$TST(keyword=*.(i_cache|i_cache_h|i_fresh):[12].*)" Match = "\0&$LOG(CRESP $DTM© : Expires killed: \0)" In = TRUE Out = FALSE Key = "Cache-Expires: Kill: Cache!/Fresh! 4.12.23 (cch!) [mona] (d.0) (In)" URL = "(^$KEYCHK(^S))$TST(keyword=*.(i_cache|i_cache_h|i_fresh):[12].*)" Match = "\0&$LOG(CRESP $DTM© : Cache-Expires killed: \0)" gorgan |
Jan. 23, 2005, 03:26 AM
Post: #70
Thanks gorgan
![]() The filters target two different response headers. "Cache-Expires" is by far not as common as "Expires", but has the same effect. sidki |
Jan. 24, 2005, 06:11 AM
Post: #71
I get a SSL certificate verification error at
addons.mozilla.org http://update.mozilla.org/?application=firefox http://https..addons.mozilla.org/?application=firefox Only appears when using your cfg. Code: ---- Certificate Errors ----Oct 1, 2004 Roots Certificate Update installed |
Feb. 06, 2005, 05:37 PM
Post: #72
the various Bottom Add: Display filters are not working for me on Firefox.
i know they use the onmouseover function but nothing happens. they work fine on IE. this occurred before i installed any extensions. i am using Java 5.0 Update 1 any suggestions? |
Feb. 21, 2005, 03:23 PM
Post: #73
nolan_vode Wrote:I get a SSL certificate verification error atI wouldn't think so. Maybe your other configs didn't filter those HTTPS pages for some reason? I don't get any warning from Prox just now, but i do recall seeing the same thing because Prox couldn't handle regexp'ed certificate hostnames. sidki |
Feb. 21, 2005, 03:25 PM
Post: #74
traviscn Wrote:the various Bottom Add: Display filters are not working for me on Firefox.Should work. Check if you've disabled any JavaScript features under Options -> Web Features -> Advanced. These things don't depend on Java. sidki |
Feb. 22, 2005, 03:57 AM
Post: #75
sidki Wrote:Maybe your other configs didn't filter those HTTPS pages for some reason? O.k. It isn't happening for me anymore either.
