sidki's config set: 2005-06-09
May. 23, 2005, 07:33 PM
Post: #256
Lovecraft, i can't do the flyover for filters that are enabled in scripts, without adding a lot of overhead. Sad
(If someone knows how to do e.g. "onmouseover=PrxFlShow('\1','\2')" without single or double quotes - even not backslash-escaped ones, i'm all ears. Smile! )
Yeah, the browser's tooltip would be an alternative, but it disappears after a few seconds, and i can't copy text from there, both of which i dislike.
I agree with ProxRocks, "kill display" or even more "debug mode" isn't something most people want to have turned on all day (although i currently do). I don't know if you saw that, but you can change these settings on the fly now for the current session:
Open the Prox Menu, check "Debug Mode", and hit the "Session" button. Later, if you want to go back to normal, don't select anything, and hit "Session" again (or reload the config).
The kill display for banners are actually two links: left is the <a> href, right is the <img> src.
I've added this to Abbreviations.txt - thanks for the hint:
Quote:*******************************************************************************
Kill Display and Log Abbreviations
Ad list matches:
AdH off-domain ad host
AdHr on-domain ad host
AdD ad domain (off-domain subdomain)
AdLr direct AdList match (on-domain subdomain)
AdP off-domain ad path
AdPa absolute on-domain ad path
AdPr relative ad path
Ad keyword matches in scripts:
AdKey.1 matched at start of code
AdKey.2 followed a "."
AdKey.3 followed a "+" or any type of space
AdKey.4 followed a "="
AdKey.5 followed a single or double quote
BTW: The previous "AdKeys" was merged into "AdList". The previous "AdStrings" in turn is now called "AdKeys".
PS: I'll have to rethink kill display at some point anyway. The current color coding for instance needs to go. It's no proper HTML (multiple ID assignments), and future browsers may not support it. But i probably still have a couple of years time for that. Smile!
sidki
May. 23, 2005, 08:31 PM
Post: #257
Thanks for explanation, no problem, I understand the contras.
Usefull the abreviation info.
Quote:PS: I'll have to rethink kill display at some point anyway. The current color coding for instance needs to go. It's no proper HTML (multiple ID assignments), and future browsers may not support it. But i probably still have a couple of years time for that. smile.gif
You'll find a good solution...I'm sure Wink
There is not dead wich can eternal lie. Yet with strange aeons even death may die.
May. 23, 2005, 09:58 PM
Post: #258
sidki3003 Wrote:...isn't something most people want to have turned on all day (although i currently do).
lol, me too... (albeit, by way of that 'session' button...)
thanks for the abbreviations, very useful...
May. 24, 2005, 07:56 PM
Post: #259
Fixed beta bugs (those that are limited to single filters):
Google untangler didn't untangle all links:
Name = "Google: Multi URL Untangler     5.05.21 (multi) [sd] (d.s) WIP2"
URL = "$TYPE(htm)([^.]+.google.|216.239.|66.102.[#0:15].|64.233.1[#60:91].)"
Bounds = "<a\s*>"
Match = "<a(*href=)\1$AV(/url\?*=(http(s|)://)\2((\3\&[a-z]=|\3%26[a-z]%3D)[#1:*]|\3))\4"
Replace = "<a id=proxPref\1"\2$UESC(\3)"\4"
Half-SSL filter didn't convert all links:
Name = "<*>: Half-SSL     05.05.20 (cch! multi) [sd jjoe] (d.2) WIP6"
URL = "$TYPE(htm)$TST(keyword=*.i_ssl_h:[12].*)"
Bounds = "<[abefilmst]*>"
Match = "*https://"
"(*\s(href|src)=\\+"+ )\1https://\2"
"|(\1https://\2&(^$TST(\1=*\= \\+"+ (http:/|/|..|)/*)))"
"&(^<input*type=$AV(text|hidden))"
Replace = "\1http://https..\2"
Washington Post photo section was broken:
Name = "<script> Block: Ad Scripts     5.05.23 [pr sd jd] (d.2) WIP22"
URL = "$TYPE(htm)(^$TST(keyword=*.(a_ads|a_js|a_adjs|a_adscr).*))"
Bounds = "<script$INEST(<script,</script)"
Limit = 2400
Match = "<script[^>]+>"
"*.write(ln|)\("$TST(flag=*.chop_b:[12].*)(<(/|)|-)([a-z!-]+{0,10})\#"
" "+{1,*} \+ "+{1,*}([a-z! -]+{0,20})\#"
"$SET(9=: \#+\# :)$TST((\#\#)=(img|ifr|div|lay|nos|!--|-)*)*"
"*<(iframe)\9"
"$TST(flag=*.iframe_b:[12].*)"
"|[^>]++src=$AVQ([^/.]+//(^([^/]++.|)$TST(uDom))*)"
"$TST(flag=*.adkey:1.*)"
"($LST(AdKeys))\8 [^a-z0-9](^\=)$SET(9=AdKey.1 \8)"
"|*.($LST(AdKeys))\8[^a-z0-9"']$SET(9=AdKey.2 \8)"
"|*\+($LST(AdKeys))\8[^a-z0-9]$SET(9=AdKey.3 \8)"
"|*\s($LST(AdKeys))\8 ([^a-z0-9,;&(]|\((^[a-z0-9_, ]+\) {))$SET(9=AdKey.3 \8)"
"|*\=($LST(AdKeys))\8[^a-z0-9]$SET(9=AdKey.4 \8)"
"|*"($LST(AdKeys))\8"$SET(9=AdKey.5 \8)"
"$TST(flag=*.adurl:1.*)"
"*\= [\[(]+\\+"+(^(^ [a-z0-9:_-]+{0,20}/))$AV( $LST(AdList)*)"
"|*" (:|(http|ftp)(s|):)(^(^//))$AV( $LST(AdList)*)"
")\1"
"&(^*<frameset)"
"&$TST(script=1)(^$TST(comment=2))$SET(script=void)"
"&$SET(eAdJS=$GET(eAdJS)<span class=ProxFlyVar>$GET(mHead) Content:</span>   \9<br />)"
"&$SET(0=$TST(keyword=*.i_debug:[12].*)"
"<span id=proxAdScript class=Prox style=display:$GET(displayD)>"
"? JS Ad: \9</span>"
"&($TST(volat=*.log:2.*)$ADDLST(Log-Main,[$DTM(d T)]\tWEB JS_Ad_HTM\t\9 \t\u)|)"
Replace = "\0<script type=text/javascript src=http://local.ptron/sidki_h_$GET(cfg)/dummy.js>\1"
Harmless images/CSS/JS were blocked at times:
Key = "Location: 1 Kill false Image/Favicon Redirects     5.05.24 (full) [sd] (d.2) (In) WIP8"
URL = "$TST(uExt=bmp|gif|ico|jp(e|)g|png)(^$TST(keyword=*.(a_location|i_light:[12]).*))"
Match = "(^*.(bmp|gif|ico|jp(e|)g|png)(\?*|(^?))|([^/?]+/)+$TST(uFile))(?*)\1&($TST(uFile=(favicon)\2)$SET(3=sidki_h_$GET(cfg)/favblue.ico)|$TST(uExt=\2)$SET(3=killed.gif))&$LOG(wRESP $DTM(c) : Connection killed: No \2: \1)($TST(volat=*.log:2.*)$ADDLST(Log-Main,[$DTM(d T)]\tHDR_In Location\tNo \2 \t\1 \t\u)|)&$RDIR(http://local.ptron/\3)"
Key = "Location: 2 Kill false CSS/JS Redirects     5.05.24 (full) [sd] (d.2) (In) WIP6"
URL = "$TST(uExt=css|js)(^$TST(keyword=*.(a_location|i_light:[12]).*))"
Match = "$TST(uExt=\2)(^*.$TST(\2)(\?|(^?))|([^/?]+/)+$TST(uFile))(?*)\1&$LOG(wRESP $DTM(c) : Connection killed: No \2: \1)($TST(volat=*.log:2.*)$ADDLST(Log-Main,[$DTM(d T)]\tHDR_In Location\tNo \2 \t\1 \t\u)|)($TST(volat=*.log:[12].*)$ADDLST(Log-Rare,HDR_In Location\tNo \2 \t\1 \t\u)|)&$RDIR(http://local.ptron/sidki_h_$GET(cfg)/dummy.\2)"
Speed things up a little:
Name = "<img>... Remove: Ad Images     5.05.22 [pr sd] (d.2) WIP9"
URL = "($TYPE(htm)|$TYPE(js))(^$TST(keyword=*.(a_ads|a_adban).*))"
Bounds = "<i(mg|nput(^$TST(keyword=*.a_adform.*))|mage)\4(^$TST(tAnc=*))[^>]++\ssrc=(\\(")\2 (*(\\$TST(\2))\0)\1|$AVQ(("|)\0 \1))*>"
Limit = 1024
Match = "$TST(flag=*.addim:[12].*)$TST(\1=[^/.]+//(^([^/]++.|)$TST(uDom))*|\+*)"
"(width(=\\+"+| :) [#60:*]*height*&&$LST(AdDimensions)*)"
"|(height*width(=\\+"+| :) [#60:*]*&&$LST(AdDimensions)*)"
"*\salt=\\+"+"
"$AV( (publici(dad|te)|werbung|(*\s|)ad(^-hoc)([^a-z"'][a-z0-9_-]+|vert[a-z0-9_-]+|))\8([^a-z]*|))*"
"(*width(=\\+"+| :) ([#*:*])\6&*height(=\\+"+| :) ([#*:*])\7)*>$SET(3=alt \8 \6x\7)|$SET(3=alt \8)"
"$TST(flag=*.adurl:1.*)$TST(\1=$LST(AdList)*)"
"((*width(=\\+"+| :) ([#*:*])\6&*height(=\\+"+| :) ([#*:*])\7)*>$SET(3= \6x\7)|*)"
"&(*alt=(\\(")\2*\\$TST(\2)|$AV(*))\2$SET(5= title=\2)|)"
"&(^$TST(comment=1)|$TST(tNoscript=1))"
"&($TST(volat=*.log:2.*)$ADDLST(Log-Main,[$DTM(d T)]\tWEB Image_i\4 \t\9\3 \t\u)|)"
Replace = "<span id=\0proxImage\0 class=\0Prox\0 style=\0display:$GET(displayD)\0>&#8593;"
"<a id=\0proxImage\0 class=\0Prox\0 href=\0\1 target=\0_top\0\5>i\4: \9\3"
"</a></span>"
sidki
May. 24, 2005, 09:38 PM
Post: #260
Two quick 'adjustments' (due to forum software)...
should be
"& # 8226 ; JS Ad: \9</span>"
withOUT the spaces before the semicolon...
should be
Replace = "<span id=\0proxImage\0 class=\0Prox\0 style=\0display:$GET(displayD)\0>& # 8593 ;"
withOUT the same spaces...
May. 24, 2005, 09:42 PM
Post: #261
Thanks Smile!
May. 24, 2005, 10:01 PM
Post: #262
No prob...
Just one of the things that Notepad will flag due to Unicode format if I try a save with those unconverted...
May. 26, 2005, 09:55 AM
Post: #263
I've updated the ComputerCops filter.
Since it isn't restricted to Proxomitron forums anymore and cuts away a lot, it can be bypassed with the ALT key now (press until page has loaded).
Keep your old version, if you want to see the various new "add feed to..." buttons.
sidki
May. 28, 2005, 03:15 PM
Post: #264
z12 Wrote:At news.yahoo.com I'm getting alot of matches like the following:
<Match: <a><body>: Block sel. JS Properties     4.01.22 (multi) [sd] (d.1) >
<a onMouseOut="cancelPreview()" onMouseOver="showPreview(event, 'hl_2', '/ap/20050516/ap_on_re_as/koreas_nuclear')" href="/s/ap/20050516/ap_on_re_as/koreas_nuclear">
</Match>
These are matching even though theres no matching property in the list to block.
Here's a version that doesn't always match anymore.
Name = "<a>...: Block sel. JS Properties     5.05.29 (multi) [sd] (d.1) WIP12"
URL = "$TYPE(htm)(^$TST(keyword=*.(a_jsprop|a_code).*))"
Bounds = "$NEST(<(a(^\sid\=\\+"+proxFl)|body)\s,(*\s|)(on[a-z]+=|href="+ javascript:)*,>)"
Limit = 1024
Match = "("
"\#.($LST(JSProperties))\3([^a-z.]|.[a-z])\#"
"(*\s((on[a-z]+)\1=|href="+ (javascript)\1:))+"
"($TST(volat=*.log:2.*)$ADDLST(Log-Main,[$DTM(d T)]\tWEB JS_Prop_\1 \t.\3 \t\u)|)*"
")+{1,*}\#"
"&(^$TST(script=*)|$TST(comment=1))"
Replace = "\0\@"
The delay caused by failing gets compensated by the new bounds match. I don't know yet if the latter will miss in some single-quote scenarios. Requires testing...
edit: Filter updated
sidki
May. 29, 2005, 09:25 AM
Post: #265
z12 Wrote:SpecialUAs.ptxt (list)
On every request I've been geting a Match on Line 62 of this list. Since the User-Agent header filter is checked, theres no need to log it.
added the following at bottom of list:
This doesn't work, because the User-Agent filter has to fail for UA's that aren't in the list. Going back to previous handling, concerns the beta only (critical bugfix - attached SpecialUAs.txt needs to be renamed to *.ptxt).
Key = "User-Agent: Handle specified UAs - Set Var      4.05.29 [sd] (d.r) (Out) WIP2"
Match = "\0&$SET(hOrigUA=\0)&((^$TST(keyword=*.(a_headers|a_ua).*))$LST(SpecialUAs)|$SET(1=\0))"
sidki
May. 29, 2005, 09:57 AM
Post: #266
Lovecraft Wrote:When I enable it lines like "&#8593;Link: AdD melodiasmoviles 300x50" break the page layout
and some pages don't return to the original when dissable.
Information about killed code will be word-wrapped now, i hope that helps a bit. Smile!
You can do it in your copy by removing the "white-space: nowrap !important;" line within the longish declaration in ProxStyles.css that starts with ".Prox,".
sidki
May. 30, 2005, 09:13 AM
Post: #267
sidki3003 Wrote:Information about killed code will be word-wrapped now, i hope that helps a bit. Smile!
sidki
Coooooooooool !!!! Smile!
God (and simple Wink ) solution, all information and no break layout anymore.
Cheers
Thanks Hail
May. 31, 2005, 12:33 AM
Post: #268
Hey, so we're all happy again. Smile!
May. 31, 2005, 03:45 PM
Post: #269
sidki3003 Wrote:I've got another beta&nbsp; ready, this one isn't that shaky anymore, so why not mention it here. Smile!
If all runs well, it will have a short lifespan, until the next release is ready to go.
I was wrong: Beta 3.
sidki
Jun. 01, 2005, 02:01 PM
Post: #270
Running Beta 3 -- so far working just great.
However the following site seems to pass a lot of adds:
http://maps.msn.com/(3lwhe3ni1jk41m55pqn.../Home.aspx
