How to test a variable against another variable?
Aug. 21, 2008, 04:04 AM
I am trying to write a filter which will add links to Google cache results to allow continuing using the cache, just like this userscript does.
I intend to add links only for those urls which are from the same host, so I use below code to extract the host address and sotre it in a global variable for later use.
(This is Google's cache of <a[^>]+>http://\1/*</a>)\0$SET(currentHost=\1)
The next step is to match only the urls from the same host. I tried below code but it seems the $GET command can't be expanded in match field just like the help file stated:
<a*href=$AV($GET(currentHost)/\2)*</a>
Then I tried to capture the host part into a variable:
<a*href=$AV(\7/\2)*</a>
and tested it with the currentHost variable in the replace field but it doesn't work either.
$TST(\7=$GET(currentHost))$SET(......)
Any ideas?
Aug. 21, 2008, 04:14 AM
RE: How to test a variable against another variable?
I find variables confusing sometimes; try reading Sidki's "Techniques" file, I think some of it might apply to what you're trying to accomplish: http://sidki.proxfilter.net/prox/sidki-e...niques.txt
Aug. 21, 2008, 05:28 AM
I read that already and even searched sidki's config set but couldn't find an example on testing variable against variable. Banging Head
Is there any other way to do what I want to do?
Aug. 21, 2008, 03:03 PM
(Aug. 21, 2008 04:04 AM)whenever Wrote:  The next step is to match only the urls from the same host. I tried below code but it seems the $GET command can't be expanded in match field just like the help file stated:
Finally worked out a way by using a memory block list for the hostname match.
The below filter is just for demonstrating the technique and may not ready for real use.
Name = "Add cache links to Google cache results page"
URL = "[^/]+/search\?*q=cache"
Match = "(This is Google*s cache of <a[^>]+>http://\1/*</a>)\0$SET(currentHost=\1)$ADDLST(Mem-Temp,\1)|"
        "(<a*href=$AV(http://$LST(Mem-Temp)/\1|/\1)*</a>)\0$SET(2= <a href="http://www.google.com/search?hl=en&q=cache:http://$GET(currentHost)/\1"><img src="http://www.google.com/favicon.ico" style="border: none;" /></a>)"
Replace = "\0\2"
Oct. 08, 2008, 09:56 PM
whenever Wrote:The next step is to match only the urls from the same host. I tried below code but it seems the $GET command can't be expanded in match field just like the help file stated:
...snip...
Any ideas?
Here's a test filter that does what you want, I think.
Name = "New HTML filter"
Match = "$SET(foo=http://www.foobar.com)"
        "(<a*href=$AV($TST(foo)/\2)*</a>)\3"
Replace = "\3"
In the log window, these will match:
<a href="http://www.foobar.com/foo_for_all/" >foo for all </a>
<a href="http://www.foobar.com/foo_for_one/" >foo for one </a>
This one does not:
<a href="http://www.nofoo.com/foo_for_all/" >foo for all </a>
z12
Oct. 10, 2008, 03:28 AM
Thank you z12. I found that trick was documented in the help file too, just inside the $TST() command section.
Each time I reread the help file, I learn something which was not noticed or understood before.
So, here is an improved filter without using a memory block file.
URL = "$TYPE(htm)[^/]+/search\?*q=cache"
Match = "This is Google*s cache of <a[^>]+>http://\1/*</a>$SET(currentHost=\1)PrxFail|"
        "(<a*</a>&&*href=$AV(http://$TST(currentHost)/\1|/\1)*)\0$SET(2= <a href="http://www.google.com/search?hl=en&q=cache:http://$GET(currentHost)/\1"><img src="http://www.google.com/favicon.ico" style="border: none;" /></a>)"
Replace = "\0\2"
Oct. 10, 2008, 08:42 AM
whenever Wrote:Each time I reread the help file, I learn something which was not noticed or understood before.
Same with me. It's definitely not a file you read just once.
As Kye-U mentioned, sidki's Techniques.txt is also quite helpful.
Especially in regards to variables.
BTW, as per your thread title, this tests if two variables, to & tc, are equal:
$TST(to=$TST(tc))
While this may seem obvious to some, it took me a while to figure it out.
z12
Oct. 10, 2008, 09:04 AM
Great! Now it seems obvious with knowing the above trick.
I learned another trick about $TST() at Castlecops, maybe you are interested in it too.
Oct. 10, 2008, 12:30 PM
If you use "This is Google's cache of", this will only work for english people. In my case, being spanish, i see "Esta es la versión en caché de" so it will never match. Please let's tray doing global filters.
How? Taking "currentHost" from the actual url of the cache
$URL(*cache:*:(*)\5/*)$SET(currentHost=\5)
Name = "Google cache: Add cache links to Google cache results page {whenever,ln}081010"
Bounds = "$NEST(<a\s,</a>)"
Match = "(*href="
        "$TST(V_Postbody=1)$URL((*cache:*:)\4(*)\5/*)$SET(currentHost=\5)"
        "$AV(http://$TST(currentHost)/\1|/\1)*)\2"
Replace = "\2<a href="http://www.google.com/search?q=cache:http://$GET(currentHost)/\1"><img src="http://www.google.com/favicon.ico" style="border: none;" /></a>"
I like this filter, thanks for it Wink
Updated: Changed "/search?hl=en&q=cache" to "/search?q=cache"
Oct. 10, 2008, 01:18 PM
That's better. I made some improvements based on your filter to cover the below situation:
cache:www.test.com&other=
No http:// between, no ended "/"
cache:www.test.com
currentHost is the last parameter
Name = "Add cache links to Google cache results page {whenever,ln}081010"
Bounds = "<a*</a>"
Match = "$URL(*cache:(http://|)(\3)([/&]*|))$SET(currentHost=\3)"
        "(*href=$AV(http://$TST(currentHost)/\1|/\1)*)\2"
Replace = "\2<a href="http://www.google.com/search?hl=en&q=cache:http://$GET(currentHost)/\1"><img src="http://www.google.com/favicon.ico" style="border: none;" /></a>"
Oct. 10, 2008, 06:30 PM
Better again. Thanks! Wink
Oct. 11, 2008, 05:55 AM
Since host extraction is excuted each time, there is no need to use a global var any longer. The below new version also improved the host extraction and took care of the :// encoding.
Name = "Add cache links to Google cache results page {whenever,ln}081011"
Bounds = "<a*</a>"
Match = "$URL(*cache(:|%3a)(http(://|%3a%2f%2f)|)([^/&]+)\1*)"
        "(*href=$AV(http://$TST(\1)/\2|/\2)*)\3"
Replace = "\3<a href="http://www.google.com/search?q=cache:http://\1/\2"><img src="http://www.google.com/favicon.ico" style="border: none;" /></a>"
Oct. 11, 2008, 10:13 AM
whenever Wrote:I learned another trick about $TST() at Castlecops, maybe you are interested in it too.
At first glance, the castlecops $TST looks a bit odd.
Basically it's just this:
$TST(VariableName=Matching expression)
$TST(VariableName=*)
$TST(keyword=*)
$TST(keyword=\1)
Both the * and \1 match the current value of the VariableName.
The \1 has the added bonus of saving that value.
You can do this wherever you can use $TST().
BTW, personally, I would put the \s back into your filters Bounds expression.
Bounds = "<a\s*</a>"
It's a bit safer.
Perhaps you should post your filter in Website Customization when your done with it.
More people will probably see it there. Smile!
z12
Oct. 11, 2008, 12:21 PM
You are right on the \s. The fixed version is posted here. Smile!
Oct. 11, 2008, 01:52 PM
Agree!!
I used sometimes a\s but sometimes i removed it to test for area, but i still haven't tested it by now. I will play with (a|area)\s
More ideas are welcome;)
Edited: Deleted what i said about $NEST or $INEST, it's usefull for tables, but not here. It's also confusing sometimes, so i removed it from here for that reason.
