Galleries of images
Oct. 13, 2008, 03:59 PM
Cool Galleries of images
These are my filters for galleries of images. It works in two differents ways:
If "See only images" is disabled, it will work only if you push ALT key while loading the page.
If "See only images" is enabled, it will always work unless you push ALT key while loading.
Name = "See only images {ln}081010"
Limit = 50
Match = "<start>"
Replace = "$SET(OnlyImages=1)"
          "$STOP()"
Name = "Galleries1: <a+img> Link to image to inline (Key:Alt to toggle) {ln}081011"
Bounds = "<a\s*> <im(g|age)*>"
Match = "($NEST(<a,*href=$AV((*.(jp(e|)g|gif|png)*)\2)*,>)"
        "($NEST(<im(g|age),*\ssrc=$AV(\3)*,>)"
        "((^$TST(OnlyImages=1))$KEYCHK(^A)|$TST(OnlyImages=1)(^$KEYCHK(^A)))"
Replace = "<img src=\2 border=1>"
          "<span class=prox2 style=display:none;><a href=\3><font color=pink>[thumb]</font></a></span>"
          "<!-- This filter matches links malformed, don't modify -->"
Name = "Galleries2: <img inline> Convert to link (Key:Alt to toggle) {ln}081010"
URL = "($TYPE(htm)|$TYPE(js))"
Bounds = "<img\s*>"
Match = "$NEST(<im(g|age),*\ssrc=$AV(\3)*,>)"
Replace = "<span class=prox2 style=display:none;><center><a href=\3><font color=pink>[Img.inline]</font></a></center></span>"
Name = "Galleries3: Removing tables and links (Key:Alt to toggle) {ln}081013b"
Limit = 1600
Match = "("
        "(< (td|table|div)*>$SET(3=[table]))|"
        "($NEST(< a,*href=$AV(\2)*,</a>))(^$TST(\2=(*.(jpe|jpg|gif|png|mpg|mpeg|wmv|avi))))$SET(3=[Link])"
Replace = "<span class=prox2 style=display:none;><font color=pink>\3</font></span>"
Edit: i removed all the $TST(V_PostBody=1) for not needing "html zones filters"
Edit2: There was an error in galleries 3, please update
Oct. 13, 2008, 06:10 PM
RE: Galleries of images
Galleries 3 updated!
