Privoxy with ProxHTTPSProxyMII v1.3a on linux
Sep. 13, 2015, 06:21 PM
(This post was last modified: Sep. 13, 2015 07:09 PM by kik0s.)
hey guys,
any chance someone can explain to me how i can get it to work on a debian distro? i followed the os x guide to install all the dependecies for python. was the same. but when i start the proxhtts.py with python it seems to work but i get some errors. i get that error on the client side. its the same on the server side ![]() Code: (host='1.2.3.4', port=8080): Max retries exceeded with url: http://www.apple.com/de/ (Caused by ProxyError('Cannot connect to proxy.', ConnectionRefusedError(111, 'Connection refused'))) thanks a lot for any help! Managed it to get running. had to change the default proxy to work with privoxy as default proxy! |
Sep. 25, 2015, 04:46 PM
(This post was last modified: Sep. 25, 2015 04:47 PM by cattleyavns.)
RE: Privoxy with ProxHTTPSProxyMII v1.3a on linux
Ah, easy, you can download my version here and take config.ini from ProxHTTPSProxy folder and replace that config file with your config file:
https://www.dropbox.com/s/2dtm8pvvc9z7bw...e.zip?dl=0 My preconfigured config.ini will work fine, i'm sure. |
Sep. 26, 2015, 06:53 AM
How did you install pyOpenSSL as i get an error installing this?
And where do the files for HTTPS proxy goes? /usr/lib/python3.2/ ? |
Sep. 26, 2015, 08:30 AM
@rogern just use any folder for the files. you can follow the guide for os x. its almost the same for linux.
Sep. 26, 2015, 09:44 AM
(This post was last modified: Sep. 26, 2015 10:01 AM by rogern.)
(Sep. 26, 2015 08:30 AM)kik0s Wrote: @rogern just use any folder for the files. you can follow the guide for os x. its almost the same for linux. Jupp it is, but i got an error code 1 Edit: Think i got it working with installing aptitude install libffi-ruby1.8 libffindex0 libffi-dev libffindex-dev libffi5 It is a striped version so i guess those packages ws not neeeded ![]() It is a another adtrap like privoxy. My setup is with urlfilter/e2guardian/squid and privoxy+dietpi on rasppberrypi 2. squid https only filter with urlfilter as i have heard |
Sep. 26, 2015, 12:29 PM
(This post was last modified: Sep. 26, 2015 01:07 PM by rogern.)
Got this error
[email protected]:/usr/local/lib/python3.2/ProxHTTPSProxy_py-1.3a# python3.2 ProxHTTPSProxy.py Traceback (most recent call last): File "ProxHTTPSProxy.py", line 27, in <module> from ProxyTool import ProxyRequestHandler, get_cert, counter File "/usr/local/lib/python3.2/ProxHTTPSProxy_py-1.3a/ProxyTool.py", line 17, in <module> import selectors ImportError: No module named selectors Changed it to import selectors did fix it though [email protected]:/usr/local/lib/python3.2/ProxHTTPSProxy_py-1.3a# python3.2 ProxHTTPSProxy.py Traceback (most recent call last): File "ProxHTTPSProxy.py", line 27, in <module> from ProxyTool import ProxyRequestHandler, get_cert, counter File "/usr/local/lib/python3.2/ProxHTTPSProxy_py-1.3a/ProxyTool.py", line 21, in <module> from CertTool import get_cert ImportError: No module named CertTool |
Sep. 26, 2015, 12:49 PM
Hi, you should ask here, ProxHTTPSProxy's author can help you: http://www.prxbx.com/forums/forumdisplay.php?fid=48
Sep. 26, 2015, 07:51 PM
as far as i know you need the dev version of openssl for your distro. i think its that one "libssl-dev". just use apt-get install libssl-dev
Oct. 02, 2015, 07:53 AM
They are installed, but i think the problem is acctually
brew install python3 --with-brewed-openssl i only installed python3 as --with-brewed-openssl i did not find a solution ![]() |
Oct. 02, 2015, 10:30 AM
RE: Privoxy with ProxHTTPSProxyMII v1.3a on linux | |||
Oct. 02, 2015, 11:16 AM
(This post was last modified: Oct. 02, 2015 11:29 AM by rogern.)
It still complains about collectors i can change it to collectors 34, but then get another error
[email protected]:/usr/local/lib/python3.2/ProxHTTPSProxy_py-1.3a# python3.2 ProxHTTPSProxy.py Traceback (most recent call last): File "ProxHTTPSProxy.py", line 27, in <module> from ProxyTool import ProxyRequestHandler, get_cert, counter File "/usr/local/lib/python3.2/ProxHTTPSProxy_py-1.3a/ProxyTool.py", line 17, in <module> import selectors ImportError: No module named selectors find / | grep selectors shows only selectors34 |
Oct. 02, 2015, 03:33 PM
(This post was last modified: Oct. 02, 2015 03:41 PM by whenever.)
selectors is a built in module shipping since python v3.4. Please upgrade your python installation to v3.4 or above.
Or use attached ProxyTool.py. |
Oct. 02, 2015, 04:46 PM
Python 3.4 i have to install by tar as 3.2 is the newest.
When replacing the file i got this error back [email protected]:/usr/local/lib/python3.2/ProxHTTPSProxy_py-1.3a# python3.2 ProxHTTPSProxy.py Traceback (most recent call last): File "ProxHTTPSProxy.py", line 27, in <module> from ProxyTool import ProxyRequestHandler, get_cert, counter File "/usr/local/lib/python3.2/ProxHTTPSProxy_py-1.3a/ProxyTool.py", line 20, in <module> from CertTool import get_cert ImportError: No module named CertTool |
Oct. 03, 2015, 02:49 AM
It's a python installation problem if you have CertTool.py under the same directory but couldn't import it.
Oct. 10, 2015, 07:11 PM
(This post was last modified: Oct. 10, 2015 07:28 PM by kik0s.)
@rogern try this
Code: sudo apt-get install python-dev libffi-dev libssl-dev then do this: Code: $ cd ~ if you dont have build tools then do that first: Code: sudo apt-get update after that you should have a fully working copy of python3.4. you can type "python3.4" in your terminal window and it should show you some input. do you have pip3? for those needed tools? i should write some ckind of tutorial ![]() |
