Author Topic: tip for the alias list  (Read 2332 times)
« on: December 07, 2001, 01:50:39 AM »
in the alias list use this command line:
1 & $JUMP(http://www.google.com/search?num=18&q=1)
instead of the default:
my search allows 30 hits per page instead of the default 10. you can modify the hits per page changing 30 with the number you prefer.
giuseppe di mauro
cj.
    • AOL Instant Messenger - smithchasmel8
    • Yahoo Instant Messenger - chasmel8@yahoo.com
« Reply #1 on: December 07, 2001, 10:06:41 PM »
Thank you for posting altosax, and welcome to the Proxomitron Forum.
I do have one quesion though? It appears that both you links are exactly the same, set at default. Is is possible that you had erred while posting?
Thanks in advance
-.cj -
________
-cj.-
______
« Reply #2 on: December 07, 2001, 10:32:48 PM »
The replacement of course should be
1 & $JUMP(http://www.google.com/search?num=30&q=1)
30 is the changable number here ;)
The default hasn't a num=x argument at all.
« Reply #3 on: December 09, 2001, 12:38:07 AM »
sorry, my mistake due to a copy and paste operation.
the first time i wrote the message i wasn't a registered user, so i rewrote the message offline pasting a command line i used to verify possibly value of num.
thanks to job for the correct command line (the one i post shows "only" 18 hits per page :)
