http://laudanski.com/#PROXOZhen-Xjell Configuration Files Changelog for use by Scott R. Lemmon's Proxomitron.
[2001.12.26] - Release 2.00 Beta
- Added "
www.codeproject.com/script/admentor/images/" to ZXList.txt.
[2001.12.23]
- Added Tame Javascript from:
http://www.geocities.com/u82011729/prox/filter.html#tamescripts. This consists of two filters "Tame Javascript" parts 1 and 2. Enabling both of these will break the full functionality of the "Smart pop-up windows killer" filter. Enable these only if you do not care about opening pop-up links via "Smart pop-up windows killer". TWo js files come with the filters, start and end, both of which are found in the html subdir.
- Added "Allow Right Click" web filter from this link:
http://groups.yahoo.com/group/prox-list/message/8428.
[2001.12.22]
- Added new header filter: "Location: Yahoo relocator (in)" from
http://groups.yahoo.com/group/prox-list/message/8383. This works great for the "interrupt" pages.
- Added new filter from
http://groups.yahoo.com/group/prox-list/message/8345 titled: "Yahoo interrupt automatifier". I use this tweaked up version to handle pages that come up after posting via the web interface. Changes shown here:
http://groups.yahoo.com/group/prox-list/message/8396 .
[2001.12.21]
- User-Agent for Hotmail Header Filter needed updating. I found that "hotmail.com" needed to be entered for Outlook Express to properly connect to the Hotmail server.
- Added "*.virtualratings.com/ads/" to ZXList.
- Removed the web bug code from "hotmail.htm". This file was obtained from Greg's kitchen sink originally.
[2001.12.20]
- Added hotmail.htm to the html subdir in the zxlist, which will allow the hotmail filters to work properly. The file was taken from Greg's kitchen sink filter set.
- Added two more filters to the hotmail set from Jor in this post:
http://asp.flaaten.dk/pforum/topic.asp?ARCHIVE=&TOPIC_ID=37.
- Changed the location of the hotmail.htm file in the web filter set Hotmail Login. It pointed to dhtml/html/HotMail/HotMail.htm, but now points to dhtml/html/hotmail.htm. Also added a "logo.gif" in the html subdir which is used by hotmail.htm.
[2001.12.18]
- Added " align="absmiddle"" to the "Bypass redirects in links" web filter inside the Replacement field to align the image in absolute middle. Thanks go to this suggestion from Aleks.
- Disabled the header filter: "User-Agent: (random)", where "User-Agent: (out) Rotate" does the job perfectly. Thanks to RLD, I replaced a single quotation with a carriage return for the web filter: "Kill IFRAME popups".
[2001.12.16]
- Added "am7.netfirms.com/nf-images/" to ZXList.txt.
