Author Topic: Fix bad framesets  (Read 2153 times)
Fix bad framesets
« on: January 15, 2002, 06:55:30 PM »
This filter will fix framesets, when a "webmaster" mistakenly uses the <body> tag instead of <noframes>, killing the frameset in Opera, and possibly other W3C-compliant browsers.
Name = "Fix bad framesets 1"
Match = "</frameset>*<body*>"
Replace = "<noframes>"
Name = "Fix bad framesets 2"
Match = "</frameset>/1</body>"
Replace = "/1</noframes></frameset></body>"
The first filter replaces the body tag with the correct noframes, and the second filter correctly closes the frameset and page.
Please note that to use this filter properly, you have to have both filters activated, and placed in the correct order -- 1 has to come before 2.
Edited by - Jor on 07 Apr 2002  14:29:39
Fix bad framesets
« Reply #1 on: April 26, 2002, 01:54:14 PM »
The above filters do not work right.
Corrected versions:
Match = "</frameset>*<body 1"
<body 1"
Match = "</frameset> /1 </body>"
Replace = "/1
          "</body></noframes>
          "</frameset>
Please replace if you are using these.
Fix bad framesets
« Reply #2 on: June 03, 2002, 12:15:31 PM »
Updated version:
URL = "$TYPE(htm) & $LST(BadFrames)"
<body 1$STOP()"
Replace = "/1
</body></noframes>
          "</frameset>
$STOP()"
Since I rarely encounter pages anymore where these filters are needed, I now place the offending URLs into a blocklist (BadFrames) instead, so the filters are bypassed elsewhere.
Edited by - Jor on 18 Jun 2002  15:36:19
