Author Topic: fixed filter set  (Read 5444 times)
fixed filter set
« on: March 09, 2002, 02:13:43 PM »
i've just fixed my filter set based on zxlist adding missing file.
if you use it or are interested, please download latest release from:
http://virgolamobile.50megs.com/proxomitron.html
this is the release 2.50h (7th release from zxlist 2.50).
fixed filter set
« Reply #1 on: March 22, 2002, 10:29:51 PM »
hi all,
i'm back home just from today, happy to sit in front of my home pc again :)
waiting for the new zxlist, i have upload a new release (2.50l now, 2.50i was not public) of my filter set based on zxlist 2.50 beta.
web page is the same.
sargasso
fixed filter set
« Reply #2 on: March 23, 2002, 04:47:23 PM »
Please excuse me if this is a silly question, but I'm a fairly new user. I've just installed your filter set but I can't access my Hotmail account now. I keep getting your own login screen but it won't accept my usual ID and password, it just keeps returning to the same screen.
What am I doing wrong or what should I do to avoid this?
fixed filter set
« Reply #3 on: March 23, 2002, 06:08:45 PM »
hi sargasso,
i've tested it and it works fine (from italy :), btw i've update my filter set to release 2.50m now.
try with the new release, otherwise disable the filter "Hotmail login".
to disable it, open proxomitron window, click on "web page" button, scroll all filters and uncheck "Hotmail login".
that's all. in this way you will not bypass anymore the usual hotmail web page for login.
NOTE: my filter set use ssl encryption so when you try to access Hotmail with my filter set it expexts a secure connection, do you have the needed dll's? if not download them from links provided in this forum or on my proxomitron page. if you don't want to use ssl encryption, open proxomitron windows, click on config button, then on HTTP tab and uncheck "Use SSLeay".
hope this helps.
sargasso
fixed filter set
« Reply #4 on: March 23, 2002, 11:40:08 PM »
Thanks for the additional info, but still no joy.   I've unchecked the 'Hotmail Login' which brings back Hotmail's own login screen, but I still keep getting bounced back to it when I try to enter.   Disabling Proxomitron is the only way I can get in right now, so there's obviously something on my PC that's causing it.
I'm away for a few days now but I'll try to resolve this when I get back. Incidentally, I do have the dlls for SSL in the main directory, I don't think that's the problem. As soon as I know more I'll post again. In the meanwhile, if you do have any more thoughts...
sargasso.
fixed filter set
« Reply #5 on: March 24, 2002, 01:50:09 AM »
hi sargasso,
i'm sorry but if your problem is not caused by the filter set i need more infos to help you. describe your problem in the section "microsoft help" of this forum and someone here will help you.
the last two things that i can say you about the filters are:
1. you have to place the ssl dll's in the same folder of the file proxomitron.exe (right click on them, copy and paste);
2. you have to allow hotmail cookies to access it with proxomitron enabled.
take a look in the list allowcookie.txt: if hotmail cookie is not allowed add this line:
*.hotmail.*
feel free to post again to require more help,
cj.
    • AOL Instant Messenger - smithchasmel8
    • Yahoo Instant Messenger - chasmel8@yahoo.com
fixed filter set
« Reply #6 on: March 24, 2002, 03:21:33 AM »
Hey Alto... This is great that you had done such a wonderful job on your site, as well as your release as it is based on Paul's... Now there are two very good sets for others to use. As for me I have always used Paul's since the very beginning and as it is fully loaded it is all I need. I suppose eventually as time allows I will incorporate other filters or .cfg files as I learn more of ther functions fully.
Regards,
-cj.- :)
_____
-cj.-
______
-cj.-
______
sargasso
fixed filter set
« Reply #7 on: March 26, 2002, 04:25:12 PM »
I just assumed that seeing as how Hotmail filters were included that cookies for Hotmail were also allowed - doh! Teach me to look at everything first.
Thanks again for the help.
Sargasso.
(Edited by moderator. Members are not allowed to downgrade someone - not even oneself. )
fixed filter set
« Reply #8 on: March 26, 2002, 07:57:25 PM »
hi sargasso,
from your reply, i guess that it was a cookie problem, now solved. well.
in my filter set, hotmail cookies are allowed so i guess also that you haven't correctly installed the package.
to install a filter set you have to move your file "default.cfg" and your folders "html" and "Lists" in a different location (for backup reasons), replacing them with the one provided by the author, have you installed the filters this way? if yes, the problem was in my filters, otherwise was elsewhere.
sargasso
fixed filter set
« Reply #9 on: March 27, 2002, 10:52:42 PM »
I must confess I'd simply unzipped the package to my Proxomitron folder, overwriting any similarly named files already there. I've now gone back to basics, reinstalled it all and saved the original .cfg and .txt files as backups as you said - surprise, surprise, it all worked first time as it should.
I'm afraid I'm one of those people who tends to install software then experiment with it to understand it, rather than reading often unhelpful manuals - sometimes I come unstuck though and ask stupid questions, but I've learnt my lesson, certainly with Proxomitron!
Thanks for your help, I hope my next posting on this forum will be a more contributory one.
Sargasso.
fixed filter set
« Reply #10 on: March 28, 2002, 12:21:24 AM »
happy to hear this.
i use some improved filter now respect to filter set on my proxo page, they will come out with new zxlist that is going to gold release.
take a look to new zhen xjell filters when they become available.
fixed filter set
« Reply #11 on: April 04, 2002, 02:36:23 PM »
new release (2.50n, 104 kb) of my filter set based on zxlist uploaded on my proxo page just now:
cj.
fixed filter set
« Reply #12 on: April 05, 2002, 12:12:16 AM »
More and more I like what you do!
I especially like the inclusion of the dumbsites filter.
Keep up the good work!
 BTW: What browser are you using?
Thanks,
cj.-
_____
-cj.-
______
-cj.-
______
fixed filter set
« Reply #13 on: April 05, 2002, 01:28:06 AM »
i took the header filter with dumbsites from jor's filter set (thanks :).
his filter set for opera and mozilla users is a really good one.
i'm using ie 5.5 but i need to show opera as user agent for the reasons i wrote to jakbenimble:
- some favourite sites of mine are ie hostile;
- many script are not executed if they detect opera.
if you like my filter set, take a deep look to ALL files in the folders "lists" and "html": probably you will like it even more.
fixed filter set
« Reply #14 on: April 26, 2002, 06:36:35 PM »
hi all, members,
i've just updated my filter set based on zxlist to release 2.50p now (zipped file, 88 kb).
direct link: http://virgolamobile.50megs.com/binaries/proxofilters.zip
proxo page: http://virgolamobile.50megs.com/proxomitron.html
here the changes:
* removed 3 useless filters (anyway they were setted to false);
* rearranged order of some filters;
* improved speed filtering by addition of $TYPE and $NEST
  commands practically to all filters;
* some filters and some lists updated;
* some tweaks to various filters;
* no new filters added.
remember to read the file "leggimi.txt", in both english/italian languages.
