Updated my config set again, grab it
here. (This overwrites the version in last post). Filesize: 86'910b, that is 85kb.
Changes from former version:
-Changed the User Agent (default) entry to another Dumb Sites entry;
-Updated Opera version number to 6.03 in ua-op.js and the header filter;
-Changed killed.html to valid XHTML 1.1
-Removed the Accept-Encoding filter, since returning * results in many blank pages on sites that use chunked encoding (for example
http://www.computercops.biz/ BTW, I realize chunked is transfer-encoding, not accept-encoding, but it seems that unless a valid A-e method is given, chunked will not work -- at least not in Opera6/win.);
-went through all my blocklists and my config set, and stripped out last redundant files (I believe);
-Added a new blocklist, $LST(SkipJS), for use with the Tame Javascript filters. This fixes broken site navigation on sites like nvidia.com's driver download section.
-Updated start.js and end.js with Paul Rupe's newer versions. Changes from his set:
in end.js: Renamed validateURLPROX() to validateURLPROXold(), and added two functions, validateURLPROXWDG() and validateURLPROXW3C().
in start.js: added function NoError() to stop JS error reporting (handy for use with the Winamp browser window), disabled JS navigator.mimeTypes checking (can be abused).
Tested with Opera 6.03 and Mozilla 1.0 RC3; not
completely tested with MSIE (but first look seems to indicate it does work).
Edited by - Jor on 31 May 2002 20:15:34
