Author Topic: new filter set released  (Read 14377 times)
mapsonx
« Reply #30 on: July 23, 2002, 03:26:57 AM »
Hi Altosax
the same here,
seems that hotmail has really changed its verification check.
I figured it had to be something like that.  Hope you work it out.  It was nice while it lasted.  Thanks for tryin'.
Could an auto login similar to the "YahooGroups AutoLogin'nReDirect.htm" be configured as an alternative, or are we talking about the same problem?
Rgds
- J -
« Reply #31 on: July 23, 2002, 11:07:09 AM »
sorry mapsonx,
the file hotmail.htm already was something like that. but now hotmail are using a lot of redirections:
1. when you type www.hotmail.com in your address bar it redirects to something.hotmail.passport.com/cgi-bin/login
2. when you enter your username and password it sends your data to loginnet.passport.com/ppsecure/post.srf
3. then opens the page loginnet.passport.com/ppsecure/post.srf that is blank and only sets the cookie "BrowserTest=Success%3f"
4. then it redirects to www.hotmail.msn.com/long_string_here
5. finally it redirects to somehost.hotmail.msn.com/your_box_here
i think it would be really hard to do this with a local file, if it can be done at all.
« Reply #32 on: August 04, 2002, 04:24:11 PM »
hi,
i've upload on my proxo page a new release of my filter set. download it from:
http://virgolamobile.50megs.com/proxomitron.html
here is the changelog. Read also the "filters_quick_reference.txt" in the vm_readme folder to better understand how new filters work and the notes at the end of changelog.txt.
[release 2002.08.04]
- New header filters added
  - Key = "Client-ip: Jakx Fake Client-IP Spoofer (Out)" [JakBeNymble]
  - Key = "Content-Location: Always show real URL (In)" [sidki]
  - Key = "If-Match: Always reload pages [vm] (Out)" [altosax]
  - Key = "Referer: Hide Previous hosts/Local origin (Out)" [martin0628]
  - Key = "Via: Jakx *Original* Proxy Spoofer (Out)" [JakBeNymble]
  - Key = "X-Forwarded-For: Jakx Fake ISP Spoofer (Out)" [JakBeNymble]
- New web filters added
  - Name = "Remove Pre-HTML JavaScripts" [sidki, altosax]
  - Name = "Log all Comments" [altosax, sidki]
  - Name = "Remove Comment-Block Ads" [sidki]
  - Name = "Disable Auto-Frame-Out Jumper [vm]" [altosax]
  - Name = "Hotmail Login Page Cleaner [vm]" [altosax]
  - Name = "IE: Replace Malicious ClassIDs" [sidki, altosax]
- Modified header filter
  - Key = "URL-Killer: kill-a-URL" (renamed "URL-Killer: Kill known Ad URLs")
- Modified web filters
  - Name = "Inject Proxomitron support files [vm]" (added the "Saved from URL" info)
  - Name = "Link De-Obfuscator" (modified Match field)
  - Name = "Open Links In Same Window" (modified Match field)
  - Name = "Kill all Images on selected pages" (modified Match field)
  - Name = "Block Web Bugs" (modified matching values of height and width)
  - Name = "Kill JavaScript Banners" (modified Match field)
  - Name = "Defuse "While-Loop" Browser Bombs" (turned it to TRUE)
  - Name = "Blink Buster (Blink to Bold)" (turned it to FALSE)
  - Name = "Page editor toolbar" (now it is the original Paul Rupe's version)
- Removed header filters
  - Key = "Location: Hotmail Login relocator [vm] (In)"
  - Key = "Referer: Hide where we've been (Out)" (replaced by a new one)
- Removed web filters
  - Name = "Pseudo Comments-surrounded Ads Jumper [vm]" (moved into "ManagedTags.txt" list)
  - Name = "[EAH] Remove CGI banners - 1.2" (no more needed)
  - Name = "(Part 3) Prevent "Auto Jump-Back" to Links"
  - Name = "(Part 4) Prevent "Auto Jump-Back" to Links"
- Modified lists in the Lists folder
  - Updated "AdDomainList.txt", "AdComments.txt", "Bypass List.txt", "ManagedTags.txt"
            "AdHostList.txt", "AdPathList.txt", "URL Killfile.txt", "Keyword list.txt"
  - Added "AdCommentPairs.txt", "LogFind.txt", "ClassIDs.txt"
- Removed the file "htmlhotmail.htm" due to changes in Hotmail's login verification URLs
- Updated the file "htmlstart.js" used by "Tame Javascript 1" from release 1.29 to 1.32
- Updated the file "htmlpageedit.js" used by "Page editor toolbar" from release 1.6 to 1.8
- Where known, added credits to the [filter's author] in "filters_quick_reference.txt". When credits go to 2 people, the first one ALWAYS is the original author, and the second one is the author of tweaks (note: only major tweaks are accredited, not minor and fixes). Unaccredited authors can email me and i'll add their name. This was because i don't know all filters' authors.
