Hi JackRnl,
Good to see you on the FORUM!
Welcome. Here is a filter that you might want to try out also.
--------Start Filter--------
Key="Referer:(out) "Rotation"th"
URL="(^asp.flaaten.dk/w|$LST(Exceptions))"
Match="$LST(Referers)"
Replacement="1"
--------End Filter-----------
REMEMBER to leave the " out of the filter values, they just show where the values start and where they end. Also you will notice the (Exceptions)in the URL line, you can create a list in the Proxo list folder with note-pad or some other text editor, and every "site" you put into the list will not get a fake referer. Sometimes when you log in to a site, the "Fake referer" Filter will re-direct you to that site! So I added an exception list to stop that from happening.
Here is a link for a list of Fake Referers you can download for the Sub-Forum.
http://arne.jaha.dk/read.php?f=1&i=42&t=42Once you download the list and put it in the Proxo lists Folder, you have to set the path from the filter to the list. On the Proxo dialog box click Config>Blockfile>Add. When the search box opens, click on the Referer list, and then open! Now you have to enter the name of the List as it "Appears" in the Filter Values, Referers.
Now with the filter enabled, it should give sites, one of the Fake Referers from the list.
Let me know how it comes out. I hope that you have a Wonderful & Delightful Day , My FRIEND!
"Jak"
Edited by - JakBeNymble on 08 May 2002 03:31:33
