New Update.
[2002.06.21]
- Updated the Google filter set.
- Updated the Yahoo group filter set.
- Reordered config. (again) *big grin*
- Removed the improper use of $NEST in most filters. (I'm no longer haunted by Scott's voice.. LoL)
- Updated some filters. (excluding the $NEST fixes)
- "Insert Style Sheet - Links {1.d.se}"
- "Insert Style Sheet - Show Kills {2.d.se}"
- "Java ID jammer {5.a} "
- "Smart pop-up windows killer {4.d.se}" (It's now the one from the default config)
- "Kill anti-cache meta tags (3.d)"
- "Proxomitron Toolbar {4.d.se}"
- "Kill - javascript banners {6.d}"
- "Kill - ad banners by size {6.d}"
- "Kill - comment block ads {6.d}"
- Updated a few lists.
- "Ad - PathList.txt"
- "Header - Client-IP.txt"
- "Header - Via.txt"
- "Header - X-Forwarded-For.txt"
- "Managed Tags.txt"
- Updated some of the url's in the bypass/allow lists.
- Removed some filters.
- Web Page
"Allow automatic page refresh"
"Foreign content-type filter"
"Allow <meta> cookies"
- Added some filters
- Web page
"Kill - all Images on selected pages {8.e}"
"Open Links In Same Window (part 1) (6.a)"
"Open Links In Same Window (part 2) (4.a)"
"Image links to Inline Images - (Not for normal use!) (9.e)"
"JS Nuker - HTML {5.d}"
"JS Nuker - External JS Files {5.d}"
"Force pop-ups to have browser controls {2.d.se)"
"Restore pop-ups after a page loads {2.d.se}"
"Disable <meta> cookies {3.c.d}"
"Disable JavaScript cookies {3.c.d}"
"Add Time to Title, Snip Excess (3.d)"
"Kill Fixed Backgrounds {3}"
"Warp2 Search BG killer"
"Block Browser Info in JS (Misc.) {7.a}"
- Header
"URL: Add to BlockFile - AllowCookies"
"If-Modified-Since: Proxo Workaround (Out) {1.d}"
- Added the missing ACR list to the blockfiles. (sorry about that) x_X
DL my config set (95k) - Install notes in Readme
Edited by - JD5000 on 22 Jun 2002 02:09:22
