Author Topic: Popup Testing Page  (Read 2932 times)
Popup Testing Page
« on: May 30, 2002, 05:45:20 PM »
Here is the link to an "Online popup-killing software tester". Cj posted it over at ComputerCops.
http://www.webknacks.com/aptest.htm
Really useful if you're messing around with your popup filter, like i do
Popup Testing Page
« Reply #1 on: May 30, 2002, 06:50:28 PM »
Thanks for the link, made me finally see just what my current filter set cannot do yet :) (test A1, B1, B5 fail with my set... I think. I don't much care about B1 and B5, but A1 needs to be worked on )
Another great test suite is here: http://www.geocities.com/u82011729/prox/js_test.html
This checks for just about any annoying ECMAScript method I know of.
Popup Testing Page
« Reply #2 on: May 30, 2002, 07:45:33 PM »
Yes, i stumbled over that one, too.
Very useful, as is his whole site (Paul Rupe).
Popup Testing Page
« Reply #3 on: May 30, 2002, 07:55:52 PM »
I didn't get any pop-ups until the last one.. I needed to add "setInterval|setTimeout|captureEvents" to the "Stop browser window manipulation" filter.
Name = "Stop browser window manipulation"
URL = "($TYPE(htm)|$TYPE(js))"
Limit = 128
Match = "(setInterval|setTimeout|captureEvents|resize(By|To)|move(To|By)"
        "|((window|self|).(blur|focus))|scroll(To|by))1"
Replace = "Prox1"
I used Paul Rupe's site when I first started putting my config together.
Popup Testing Page
« Reply #4 on: May 30, 2002, 09:27:42 PM »
Interesting. Did you do anything with WindowOpen.js?
Popup Testing Page
« Reply #5 on: May 30, 2002, 09:43:04 PM »
Nope, I just had the following filters active.
Kill alert/confirm boxes
Smart pop-up windows killer
OnUnload unloader
I had to disable "Kill Nosey JavaScripts v1" for the scripts to work. LoL
Edited by - JD5000 on 30 May 2002  22:47:40
Popup Testing Page
« Reply #6 on: May 30, 2002, 09:53:38 PM »
Ok. I just tested it with your modified config, it's similar to start/end js.
Start.js does this:
crippleFunctionPROX('resizeTo');
crippleFunctionPROX('resizeBy');
crippleFunctionPROX('moveTo');
crippleFunctionPROX('moveBy');
crippleFunctionPROX('scrollTo');
crippleFunctionPROX('scrollBy');
crippleFunctionPROX('blur');
crippleFunctionPROX('focus');
crippleFunctionPROX('setInterval');
// crippleFunctionPROX('setTimeout');
crippleFunctionPROX('captureEvents');
crippleFunctionPROX('close');
I had to disable 'setTimeout', because a couple of menues need it.
But it still passes the test.
Popup Testing Page
« Reply #7 on: May 30, 2002, 09:57:35 PM »
Yup, thats were I got the idea from.
I had to disable 'ProxsetTimeout', because a couple of menues need it.
Hmmm, I think I'll remove that then.
pandoras_box
Popup Testing Page
« Reply #8 on: June 06, 2002, 05:42:48 AM »
Thanks, sidki3003
Just try the site, the Proxo works fine for most of test, although the filter fails in A1, B1 & C2 test.
I have some troubles in dealing "Test C2. The stubborn popup".  A dialog box will jump up telling me to close the popup killing software and this dialog box could not be closed. I have to close the browser completely to solve this problem.
JD5000, does the filter you just mention here stop the last one?
Popup Testing Page
« Reply #9 on: June 06, 2002, 06:00:09 AM »
If I remember correctly, to pass "Test C2" you need to enable "Kill alert/confirm boxes".
~HTH, JD
Popup Testing Page
« Reply #10 on: June 06, 2002, 06:03:42 AM »
Yes.
JakBeNymble
Popup Testing Page
« Reply #11 on: June 06, 2002, 06:40:46 AM »
Hi "Friends",
             No Pop-ups here at all. However, I think my set is so "tight" that I couldn't click the window in the 4th test http://www.webknacks.com/aptesta4.htm.
Good Test-pages though!
Have a Wonderful day, My Friends,
"jak"
"The Ancestor of every Action is a Thought."-Emerson
punkrawk
    • http://www.DavidsInter.net
Popup Testing Page
« Reply #12 on: August 20, 2002, 06:37:39 PM »
Did anyone get all the test to work correctly?  If I click a button I should be able to open the window.  Right now I block everything.  I "failed" a few of the tests because I couldn't open a window.
-Punkrawk
Anime!
David's Internet
-Punkrawk
Anime!
David's Internet
