Hi Proxo-Friends,
Here is a great little program that does a lot of great big things. It's 3D Trace-route Program. It's one of the few proggies that will actually Do more than what is advertised.
However, if You do check it out, don't download the Newest Beta version(1.6.36:83). It has a problem with the built-in browser.
I downloaded the next older version(v1.6.35:80 2002-08-18) and it didn't have the browser problem. Also when You install it, it automatically adjusts to Your Default browser settings, so if Your default browser is set-up to use "Proxo", then I suppose ALL the Browsing features should be routed through "Proxo". I'm not sure about that, I haven't tested it that far Yet!
Here's a list of the Features:
Core features:
3d traceroute display, multiple graphics modification options
statistic-window with min, max, average, standard deviation
Whois query to everything with one click
history-window with destination ping time
record and playback: record any trace and playback step by step
and the browser is already built in.
3d Traceroute besitzt eine integrierte deutschsprachige Oberfl?che.
Einfach starten, Umschaltung erfolgt automatisch.
Day and Night trace: Admins beloved toy
Command-line execution mode. Full replacement for good old buddy tracert.
Domain Harvester: helps to find similar domains
passive OS fingerprinting
Port scanner (knows 3,612 well known ports)
IP-Range-Scanner (scan from Start-IP to End-IP)
analyze eMail headers against RBLs
HTTP Server Spy
build in TELNET client
long period Ping and HTTP monitor
Low CPU-Usage
Working with 98, ME, 2K, XP
and if you are lucky, 95, too!
Here is the link for download & ScreenShot:
http://www.hlembke.de/prod/3dtraceroute/I think it's a great 'Tool' that any "Computer-Enthusaist" would want to have.
Hope You have a Great & Wonderful Day,
"Jak"
