Hi "Proxo-Users",
I just finished a project I had been working on for the last little bit. I've tested and it seems to work fine.
You know that the single secondary most tell-tale bit of information that those Nasty-Nosy Sites uses to track You all over the Net is the Referer. Or at least that's what I believe. How would You like to be able to automatically:
(1)."Allow" referers on trusted sites.
(2).Automatically have Proxo return the site's own URL as the referer as normal surfing.
(3). Automatically have rotating "Humourous Fake referers" on all the sites that You use a Remote Proxy for the connection.
(4). And Automatically Send the Ultimate Cyber Flip-OFF REFERER continuely to sites You want to get a message to?
Did I hear somebody say, sites that have started using anti-adbuster code??
The first filter's replacment text come from My Friend SidKi3003. I believe in giving credit where credit is do.
WARNING: Do Not Click On the Replacement Text of the Third Filter in Mixed Company, with Small Children in the room, or with Your Sound turned up!!! The URL is For the Nasty Sites, not You! You have been WARNED!!
Key = "Referer:(out) "Jakx-Hide where we been Hangin' Out"(a)"
URL = "(^$LST(AllowReferer)|(^$LST(UseProxy)))"
Replace = "http://h"
Key = "Referer:(out) "Jakx-Rotating Fake Referers" (b)"
URL = "($LST(UseProxy)&(^$LST(AHoSites)))"
Match = "$LST(Referers)"
Replace = "1"
Key = "Referer:(out) "Jakx-Ultimate Cyber FLIP-OFF"(c)"
URL = "$LST(AHoSites)"
Replace = "*URL is in the Referer.zip file*"
Now You need ti make a list and name it "AHoSites" and put it in the Lists Folder in the Proxo dir. Now add the Following: ($LST(AHoSites)) to Your "UseRPA" List or the "UseProxy" list, which ever on that You use.
I have renamed my "UseRPA" list, to "UseProxy" List. This is so I can try different configs out without having to overwrite my list. Just change the name in the Filters or the name of the UseRPA list, so that they have the same name is all that matters.
By adding ($LST(AHoSites)) to the "UseRPA" list, it allows You to add URLs once to the "AHoSites" Lists and at the same time it is automatically added to the "UseRPA" List. And this way by adding it to Your "AHoSites" list, not only will Proxo send that Special Referer to the site, but will also make sure that a Remote Proxy is used for the connection to that site. (I don't think I would want to send this URL to any site without using a Proxy).
And of course if You don't have an "AllowReferers" list You will have to make one of those also, and be sure to add the FORUM's URL to it or You will have trouble loggin on to the FORUM.
Now here is what happens, When You are surfing, Filter Number One makes sure that all sitesnot added to any of the lists, get their own URL for the referer.
When You surf to a site that You have entered into the "AllowReferers" List, None of the Filters return true so that site gets a real referer.
Now when You surf to a site that You use a proxy for the connection, Filter Number Two will make sure that ALL those sites get is a one of 32 different Fake referers. Here are a few examples:
http://www.jokeornot.com/gallery/ChuckGates.html http://www.jokeornot.com/gallery/4goof.htmlhttp://www.funny-city.com/cgi-bin/myfun/photos.cgi?66,viewNow Any Site that You Enter into the AHoSites List, gets just exactly what the title says, The Ultimate Flip-off! No Joke! And as long as You are on that site this same Referer gets logged over and over again.
Here is the link for the Fake referer list and it contains the URL to be Placed in the Replacment text of the Third Filter:
http://uploaded/JakBeNymble/20027125424_RefererList.zip Have a Delightful After-Noon My Friends,
"Jak"
Edited by - JakBeNymble on 12 Jul 2002 06:18:50
