Author Topic: how to filter local HTM file?  (Read 1032 times)
redhades
« on: August 11, 2002, 10:54:59 AM »
How do I configure Proxo or IE to filter webpages that are saved on my harddrive?
<?> ЯЄ?ĦΔĎΣŞ <?>
<> ЯЄĦΔĎΣŞ <>
« Reply #1 on: August 11, 2002, 11:17:41 AM »
From the PROXOMITRON HELP FILE:
http://file//path
Used to filter a local file as if it were a web page. Similar to the file:// URL used by most browsers.
So, to filter C:Temppage.html , you would use http://file//c:/temp/page.html (note: this does not work in Opera, as far as I can tell. It does work in MSIE and Mozilla, so should work in Netscape.)
To debug, bypass, or use other HTML commands in conjunction with this: http://dbug..file//c:/temp/page.html
redhades
« Reply #2 on: August 12, 2002, 12:59:55 AM »
Great, thanks!
<?> ЯЄ?ĦΔĎΣŞ <?>
<> ЯЄĦΔĎΣŞ <>
redhades
« Reply #3 on: August 13, 2002, 05:23:31 AM »
Here is a way to make it easier.
This will ad 'filter with Proxo' in the rightclick context menu of HTM and HTML files. But It only work when you are connected to the net and of course when proxomitron is running.
1-Create a plain text file and past this into it:
---Start copy down here---
REGEDIT4
[HKEY_CLASSES_ROOThtmlfileShell]
@="Filter_with_Proxo"
[HKEY_CLASSES_ROOThtmlfileShellFilter_with_Proxo]
[HKEY_CLASSES_ROOThtmlfileShellFilter_with_Proxocommand]
@=""C:\Program Files\Internet Explorer\iexplore.exe" command-file//%1"
---End copy up here---
*The red part is to make this the default action. Double-cliking the file will open it FILTERED. If you dont want this, dont past the red part or strip it after the past.
*The Blue part should reflect the path of the browser that you use.
*The green part is also optional. It's the command prefix that you set in Proxo. Strip it if you dont use a prefix.
2-Save the text file and change its extention from .txt to .reg .
3-Execute the .reg file and merge it to your registry
VOILA!, rightclick on any html file and chose 'Filter with proxo'.
You cand also achieve this by modifying the Folder options/File type tab/htm.
<?> ЯЄ?ĦΔĎΣŞ <?>
Edited by - redhades on 13 Aug 2002  06:30:58
<> ЯЄĦΔĎΣŞ <>
