Hi gang,
I've decided to upload my config in hopes of some good suggestions for improvements, additions, etc. I've been working on it for quite some time and I think I finally have it the way I want it but since my wife and I went into business for ourselves I don't have much time for testing and tweaking.
The goals I've sought to accomplish with this config are fivefold:
Security
Privacy
Effectiveness
Speediness
Simplicity
I think I have accomplished that but I'd still like your opinions.
1) Security
This config disables all active content at all sites except for those named in associated Allow lists.
2) Privacy
All the usual stuff is blocked plus this config works in conjunction with eDexter and my hosts file (included) to block all ads using a relatively small AdList. I also block P3P headers and tags.
3) Effectiveness
I'll let you folks decide that but I don't see anything getting past my filtering. My filters also do a good job of eliminating ads and web bugs without destroying page layout.
4) Speediness
These filters seem pretty quick to me on this old PII 450. I've provided two configs, the speedier of which is My_default.cfg.
5) Simplicity
In most instances I've tried to steer clear of really complex filters because they are hard to debug and I don't have the time to spend. I've also thrown out the majority of cosmetic and site specific filters. I can't see slowing down my web browsing just to correct someone elses poor coding habits.
As mentioned above this config works in conjuction with eDexter and my hosts file to block ads. If you are not running eDexter and/or you don't use a hosts file for ad blocking then this config may not work effectively for you, but here and there throughout my config you will find filters whose names differ only by "(eDexter)" or "(Standard)". In a nutshell the "eDexter" filters defer filtering to eDexter to grab a replacement image from RAM while the "Standard" filters perform the filtering using k or Local.pron to grab a file from the disk (killed.htm, killed.gif, etc) which is slower. If you have no intention of running eDexter you will need to disable the "eDexter" and enable the "Standard" filters. Ad blocking may not be as effective however.
For more info and to download eDexter please see
http://www.pyrenean.com/Aside from my hosts file this config uses a very small AdList which isn't much different from the AdPaths list. I did away with the AdDomains, AdHosts, ZXList and so on because it seemed like overkill. What I did was to take the ad block list from an old AtGuard reg file and reformatted it to work as a Proxo blockfile. Seems to be working quite well. Try it!
You can download my config at:
http://hpguru.bravepages.com/files/hpconfig.zipTo install it without messing up your current config, unzip it to its own folder and copy the following files to that folder.
Proxomitron.exe
zlib.dll
proxcert.pem
The SSL libs if you use them.
All the other files required for Proxo to run are included (in the html folder)
That's about all. If I left anything out just ask. Enjoy!
Edited by - hpguru on 15 Aug 2002 22:40:36
