Author Topic: images after HTML  (Read 3989 times)
images after HTML
« on: August 18, 2002, 10:54:10 PM »
Hi all.
I'm searching for a filter for speed up the navigation.
Is there any filter that waits to load completely the html code, and only
after that, begin to (load|download) the images?
    • ICQ Messenger - 21893433
images after HTML
« Reply #1 on: August 19, 2002, 03:06:15 PM »
Ola Inminente,
<grin> as luck would have, I've been experimenting with this, try these two
Name = "Visual: Delay Loading IMGs until Page Done (JarC)"
Bounds = "<IMG[^>]+>"
Match = "1 SRC=$AV( 2 )3&(^*PRXsrc)"
Replace = "1 SRC="http://local.ptron/clear.gif" PRXsrc="2"3"
Name = "End: Load Delayed Images [JarC]"
Limit = 1
Match = "<end>"
Replace = "
 <SCRIPT LANGUAGE=JavaScript>"
 var docIMGs = document.images;"
 for (i = 0; i < docIMGs.length; i++) {"
 if (docIMGs.PRXsrc+""!="undefined") "
 { docIMGs.src = docIMGs.PRXsrc; } } "
 </SCRIPT>
Important, if you place the 'Visual:' filter above your banner killers and such, it will need 'Multi' checked. If you place this one (way) below your banner killers, multi can be unchecked but the risk remains it will delay loading an ad and cause it to slip by filters testing for ' SRC=' (with a space in front)
Also I have used clear.gif as temp replacement to prevent the red X's
JarC
Edited by - TEggHead on 19 Aug 2002  16:22:44
images after HTML
« Reply #2 on: August 19, 2002, 06:50:28 PM »
Hi TEggHead, my "amigo".
I have been testing your filters and think that...
...YOU MADE IT!!.
I placed these filters at the end (for a safer way) and deactivated 'Multi' as you said.
The results are that these filters rocks. An indispensable filters.
My 56k modem has a new life. Now i can read the text and don't wait to load all the images.
A lot of thanks to you.
Edited by - lnminente on 19 Aug 2002  20:31:15
images after HTML
« Reply #3 on: August 19, 2002, 07:25:57 PM »
Hiya TEggHead,
Talk about an interesting filter! LoL
Does the script work in Opera? I couldn't quite tell if it does. Although, I did notice the images were the wrong size when they appeared.. LoL (e.g., the computer cops logo)
Even on cable, these filters seems to help in IE.
Great work!
~JD
EDIT: Geez, somebody needs spell check. LMAO Also, it does work in Opera.. However, the images are the same size as the clear.gif..
Edited by - JD5000 on 19 Aug 2002  20:38:55
images after HTML
« Reply #4 on: August 19, 2002, 07:28:24 PM »
Ups, one inconvenience:
If i save the page to hard disk with the browser, it saves the html and clear.gif but not the original images
Note: I think that i will can live with this
images after HTML
« Reply #5 on: August 19, 2002, 07:53:56 PM »
After a fashion... you need to cycle through the different image choices before the images appear. (press 'g' a maximum of three times).
Toggling the user stylesheet also works (ctrl+g twice).
Reloading does not work.
Images which do include width and height do work normally.
Edited by - Jor on 19 Aug 2002  21:01:55
images after HTML
« Reply #6 on: August 19, 2002, 08:03:27 PM »
to JD5000: Try this change with "Visual: Delay Loading IMGs until Page Done (JarC)"
Replace = "1 SRC="" PRXsrc="2"3"
I preffer to view how the page is loading, and the time i am not spending
images after HTML
« Reply #7 on: August 19, 2002, 08:04:08 PM »
Hiya Jor,
That does work.. Still, I hope TEggHead has an idea on how to get it to work, without that workaround..
images after HTML
« Reply #8 on: August 19, 2002, 08:09:07 PM »
Hi lnminente,
Unfortunately, that doesn't work. The images still come up tiny.
images after HTML
« Reply #9 on: August 19, 2002, 09:58:19 PM »
Cool! This also fixes the IE "max connections per server" problem too.
Edited by - JD5000 on 19 Aug 2002  22:59:45
images after HTML
« Reply #10 on: August 19, 2002, 10:07:52 PM »
What problem did you see with IE? I am using 8/10 max connections.
images after HTML
« Reply #11 on: August 19, 2002, 10:29:51 PM »
When ever I used anything above 2/4 (default), I would have some images not loading.
With this filter, I'm able to go up to 99/99. LoL I'm not going to keep it that high, I'm just testing to make sure it works.
Edited by - JD5000 on 19 Aug 2002  23:30:36
images after HTML
« Reply #12 on: August 19, 2002, 10:37:23 PM »
Ah, great! Maybe i just didn't realize that LOL.
images after HTML
« Reply #13 on: August 19, 2002, 10:48:36 PM »
I've brought it back down to 8/10. On most pages, above 8/10 works fine. But, IE still loses images on graphic intense sites. (e.g., DeviantART)
Edited by - JD5000 on 19 Aug 2002  23:49:00
images after HTML
« Reply #14 on: August 19, 2002, 11:40:49 PM »
Hi all.
Before this filter i was using using 2/2 max connections to load the html faster. At the moment i will follow with 2/2. I found it optimun for my 56k.
Edited by - lnminente on 20 Aug 2002  00:42:21
