Author Topic: Warn if changing between secure & non-secure mode  (Read 2595 times)
FCMR
« on: December 31, 2001, 10:51:34 PM »
After installing Proxomitron I found that some web sites would no longer work properly.   First I had to add "Stamps.com" to "Bypass".  Then I discovered that I also had to uncheck the "Warn if changing between secure & non-secure mode" under "Tools/Internet Options/Advanced" before all of my addresses would load properly.  Any suggestions on might have caused this would be appreciated.
Thank you.
John Miller
« Reply #1 on: December 31, 2001, 11:17:41 PM »
I have visted the site and cliked on a few pages. Nothing seems wrong here. I suggest you open the log window in Proxomitron and see which filters kick in and then untick them one by one until you find the problem maker.
If you don't have the necessay files for using Proxomitron on SSL, then you must not have it ticked in Config - HTTP
Hope it helps
