Author Topic: Local file shortcut  (Read 2264 times)
Admin
  • Forum Admin
Local file shortcut
« on: July 30, 2001, 10:29:27 PM »
http://arne.jaha.dk/download.php/1,22,12/id27.zip
Greetings!
Here is a header filter to help entry of local filenames into the browser's
location input bar.
UPDATE:
Remember to put a password in the URL command Prefix in the config dialog. Then you must add the password in red below here.
-------------------------8<----------------------------
Key = "URL: Enable local file shortcut with URL commands [x.D../PATH/FILENAME]"
URL = "(b.$SET(1=bypass..)|s.$SET(1=src..)|d.$SET(1=dbug..)|)"
      "([a-z])../(#s$SET(#=%20))+#&$RDIR(http://password1file..:/@)"
--------------------------8<---------------------------
With regards from
Admin
Local file shortcut
« Reply #1 on: August 20, 2001, 11:12:36 AM »
This filter will give you the option to get local htm files into you browser window through Proxomitron. It is used like this:
type into your URL field in your browser:
c../myfile.htm or c../mypath/myfile.htm
If you wish to bypass Proxomitron then use it like this:
b.c../myfile.htm
If you wish to see the source (the src command) use it like this:
s.c../myfile.htm
And at last you can go into debug mode with:
d.c../myfile.htm
Local file shortcut
« Reply #2 on: August 21, 2001, 02:16:53 AM »
Thanks for this filter!
Finally a version that works in Opera...
Local file shortcut
« Reply #3 on: August 21, 2001, 08:27:20 AM »
Nice to know. When you do find filters that work or does not work in Opera, I and others would appreciate your remark on it. People need to know what works in which browsers, and I do not have time to test them all. The same goes for people using Netscape. I mostly use IE and only test them in this browser.
Local file shortcut
« Reply #4 on: September 26, 2001, 10:06:33 AM »
I have made a change to this filter, since my harddisk is split into c: and d: it did not work for disk D:
I therefore changed the d into a g.
URL = "(b.$SET(1=bypass..)|s.$SET(1=src..)|g.$SET(1=dbug..)|)"
