Author Topic: JD's config set (updated 08-12-02)  (Read 46757 times)
« Reply #90 on: August 06, 2002, 02:01:31 AM »
N/P
Yes, I used to use Crazy Browser. I now use MyIE when I need to use IE. Opera is my default.
http://www.ruihehang.com/myie2/ (free & spyware free)
one firewall, Agnitum Outpost.
and one mp3 player is 1by1.
The last time I used Outpost, it would eat up about 40 megs of memory. I'm using Kerio 3.0 beta1 right now.
Can you PM me the link for 1by1?
PM = Private message.
« Reply #91 on: August 06, 2002, 04:05:20 AM »
MyIE looks cool . Can you use BHOs with it?
lnminente, for your *.dot.tk problem you can change the javascript banners filter like that:
*((<(iframe|html)|=?=?=?=?|banner_height) ...
Edited by - sidki3003 on 06 Aug 2002  05:17:13
« Reply #92 on: August 06, 2002, 04:45:48 AM »
Last I checked, the author was working on it.. It's open source, so if ya know coder, who knows... LoL
~JD
redhades
« Reply #93 on: August 11, 2002, 11:44:42 PM »
Hi JD!
I'm a newbie here and I've been using your config set for a couple of days now.
I think it's realy SaWEEEEET. Runs realy well. You must have put alot of time into this. Just the lists are huge. And its all so well organized. Perfect for lazy brains like me.
Two things though:
1-The proxomitron toolbar doesnt work with local htm. file.
2-The List folders are well organized but when you look in the
Add to blockfile> and the Edit blockFile> menu, its a real mess. I tried to organize it like you did with the webpage Filters. In Each of the List folders, I created some dummy files called like this:
---SOME NAME.---
Then I edited the default.cfg file to put some order like this:
List.---[DefaultProxoList]--- = "..Lists---Default Proxomitron Lists.---"
List.Bypass = "..ListsBypass List.txt"
List.CookieList = "..ListsAllowCookies.txt"
List.AdKeys = "..ListsKeyword list.txt"
List.---[Jd'sAdList]--- = "..ListsJd_ListsAd Lists---Jd's Ad Lists.---"
List.KillAdList = "..ListsJD_ListsAd ListsAd - AdList.txt"
List.AdDomains = "..ListsJD_ListsAd ListsAd - DomainList.txt"
List.AdHosts = "..ListsJD_ListsAd ListsAd - HostList.txt"
List.---[Jd'sBypassList]--- = "..ListsJd_ListsBypass Lists---Jd's Bypass Lists.---"
List.Bypass_Web = "..ListsJd_ListsBypass ListsBypass - Web Filters.txt"
List.Bypass-URLKiller = "..ListsJd_ListsBypass ListsBypass - URL Killer.txt"
List.---[Jd'sAllowList]--- = "..ListsJd_ListsBypass Lists---Jd's Allow Lists.---"
List.Allow-Frames = "..ListsJd_ListsBypass ListsAllow - Frames.txt"
List.Allow-Referrers = "..ListsJD_ListsBypass ListsAllow - ReferrerList.txt"
 ...(etc)
Now it easier to navigate through all those list in the Edit blockFile> menu.
<?> ЯЄ?ĦΔĎΣŞ <?>
<õ> ЯЄÐĦΔĎΣŞ <õ>
« Reply #94 on: August 12, 2002, 01:58:10 AM »
Howdy redhades,
I'm happy to hear ya like it.
---SOME NAME.---
{SNIP}
Great idea! I'm going to use it in the next release. Thx.
~JD
« Reply #95 on: August 13, 2002, 05:56:54 AM »
Finally! I finished the Ad List update. (with some help from Alto) Enjoy!
NOTE: I'll be posting a zip with only the updated lists & configs. For those who are already using my config & only want the updates.
[2002.08.12]
- Huge update to the Ad Lists. x_X
    - Updated to the current Steve Martin Hosts files
    - Merged two new Hosts files.
     - List changes
        - "ad - ZXList.txt" = "Ad - Blacklist.txt"
        - "Ad - PathList.txt" = "Ad - Paths.txt"
        - "Ad - DomainList.txt" = "Ad - Domains.txt"
        - "Ad - AdList.txt" = "Ad - List.txt"
        - "Ad - HostList.txt" = "Ad - Host Prefixes.txt"
     - List additions
        -  "Ad - Keys.txt"
        -  "Ad - User.txt"
- Renamed "JD_Newbie.cfg" to "JD_Basic.cfg".
- Renamed "Dummy.cfg" to "Add-on.cfg".
- Added separators to the lists. To make it easier when using the Proxo context menu.
  (e.g., "add to blockfile" & "edit blockfile") Thx to Redhades for the idea.
- Reordered config .. Just a tiny bit this time. ^_^
- Changed the "URL command" prefix. "Command."
- Updated filter(s) (not including minor fixes)
   -Web Pages
    -"JS Nuker - HTML {5.d}"
    -"JS Nuker - External JS Files v.2 {5.d}"
    -"Java killer {8.a.e} "
    -"Kill - ad containers {6.d} "
    -"Kill - ad banners {6.d}"
    -"URL to Title - Text Links {5.o.sp.ie}"
    -"Disable - unwanted Javascript event handlers {7.d.se}"
    -"Block - Browser Info in JS (Misc.) {5.d}"
    -"Add Time to Title, Snip Excess (3.d)"
    -"Teoma - Search Results Un-Prefixer"
    -"Convert Flash to links {8.o}"
    -"Block - Browser Info in JS (Misc.) {6.d}"
- Added filter(s)
  -Web Page
    -"Kill - flash ads by size {6.a}"
    -"DOM - Banner Blaster v0.006 {6}"
    -"DOM - Container killer v0.006 {6.se}"
    -"OpenPage to Link (2.o)"
    -"Suppress _blank/_new {4.d}"
    -"Disable - JavaScript Timers {8.se.a.e}"
    -"Allow Right Mouse Clicks {2.d.se}"
    -"Disable - status bar manipulation {4.d.se}"
    -"Disable showmodaldialog pop-ups {1.ie}"
    -"Block - Nosey elementById gets {8.a.e}"
    -"Altavista - Image search cleaner"
    -"My Yahoo - Top Text Ad Killer"
   -Headers
    -"User-Agent: Hide Extra Details (Out) {5}"
- Removed Filter(s)
  -Web Page
    -"Active X killer {8.a.e}"
    -"Remove - target="_blank" -  Base (part 2a) {5.d}"
    -"Remove - target="_blank" -  Links (part 2b) {5.d}"
    -"Open Links In Same Window (part 1) (8.a.e)"
    -"Open Links In Same Window (part 2) (8.a.e)"
  -Headers
    -"User-Agent: Default - IE/Mac (Out) {5.d}"
    -"User-Agent: Default - Opera/Mac (Out) {5}"
- Updated list(s)
    - "JS - Properties.txt"
    - "JS - Triggers.txt"
- Added list(s)
    - "Header - UA's.txt"
    - "separator.txt" - Empty list, used as a list separator.
DL my config set (145k) - Install notes in Readme
Edited by - JD5000 on 31 Aug 2002  09:15:56
« Reply #96 on: August 13, 2002, 06:51:33 AM »
OK, here it is... This zip only includes the updated files & configs. Unless you modified a lot of the bypass lists, I recommend downloading the full config set. (above)
My Lite config set (90k) - Install notes in Readme
NOTE: You need the 7-30-02 config set to use this update.
Edited by - JD5000 on 31 Aug 2002  09:48:13
mapsonx
« Reply #97 on: August 13, 2002, 08:58:29 AM »
Hello JD
Am I correct in assuming that:
1.  Filter set options 1, 2, 3 are to be used independent of eachother (I know your not supposed to use filter set #2 with ACR, but does that also go for DOM filters)?
2.  Either use one DOM filter or the other, but not both?
Thx
- J -
« Reply #98 on: August 13, 2002, 09:19:28 AM »
Ummm... I would say enable the DOM filters, then if needed, enable filters from "ad filter set #2".
mapsonx
« Reply #99 on: August 13, 2002, 03:23:46 PM »
Reason for my inquiry:
Using both DOM filters (ACR & filter set #2 deactivated) I get the following:
"The program has performed an illegal operation...."
IEXPLORE caused an invalid page fault in
module MSHTML.DLL at 0167:7ad41691.
Registers:
EAX=00000000 CS=0167 EIP=7ad41691 EFLGS=00010246
EBX=0225dc60 SS=016f ESP=0058c9e4 EBP=0058ca10
ECX=00000024 DS=016f ESI=00000024 FS=3cb7
EDX=0058c901 ES=016f EDI=0225dc20 GS=0000
Bytes at CS:EIP:
f6 06 02 75 15 ff 76 04 e8 65 10 ff ff f6 06 01
Stack dump:
00000000 7adc5bdf 00000000 7adc5b2f 00000001 0225dc20 00000000 00000003 00000000 02267ce8 00000000 0058ca70 7adc5dc2 00000001 00000000 00000000
Some examples:
http://www.pcnineoneone.com/cgi-bin/dcforum/dcboard.cgi
Trying to access threads at
http://www.computing.net/
http://www.gist.com/tv/grid.jsp
http://tvlistings.zap2it.com/gridall.asp
No problem using just one DOM filter
« Reply #100 on: August 13, 2002, 08:25:31 PM »
Hi mapsonx,
I'm guessing "DOM container killer.." is causing the problems? All those pages worked fine for me in IE6. The only thing I can think of, is to change this line in the "DOM container killer.."..
var d=6;
to
var d=5;
The DOM filter isn't the most stable filter.
~JD
redhades
« Reply #101 on: August 13, 2002, 10:18:16 PM »
I modified the 'Anti-Auto-JS-Redirection' filter's matching expression to:
 *.location(.href=|.replace()"(^['"+]) 1"*
I find it Works better this way.
And thanks JD for the credit in your new update.
Makes me feel all fuzzy inside. hihi!
<?> ЯЄ?ĦΔĎΣŞ <?>
<õ> ЯЄÐĦΔĎΣŞ <õ>
« Reply #102 on: August 14, 2002, 03:24:12 AM »
I'll try it.
Hey, it was your idea.
« Reply #103 on: August 14, 2002, 03:27:54 AM »
Howdy all,
I would like to thank Sidki for all his help in testing my config. It would be full of holes & problems if he didn't help.
Thx Sidki!
~JD
Edited by - JD5000 on 14 Aug 2002  05:10:45
Deporange
« Reply #104 on: August 14, 2002, 03:56:45 AM »
Great work, JD!!  It just keeps getting better.
Thanks for the effort and your responsiveness to suggestions.
Steve D
Steve D
