Author Topic: Naoko 4.3  (Read 23049 times)
MorpheusDreamlord
Naoko 4.3
« Reply #30 on: June 12, 2002, 09:09:20 AM »
I'm also getting the page stop problem on all sorts of pages and links opening to images - requiring a refresh in 4.3.
doesn't happen in 4.2 using the same filters
Yup, that's my point exactly, nothing has changed here on my HD except the proxo executable, and we're getting the pages cuts offs..
Update -  if you forve a dbug reload od a bad page, turn dbug off then refresh the page, all is fine. (The dbug page shows all filters are working fine - it's almost as if Proxo is scanning the incoming htm TOO fast, and on slow connections assumes no more code is the end of file (??????)). I'm pretty sure is not a filter problem.
Come to the Dreaming...
Edited by - MorpheusDreamlord on 12 Jun 2002  10:14:31
dave1006
    • ICQ Messenger - 92066376
Naoko 4.3
« Reply #31 on: June 12, 2002, 03:21:08 PM »
I'm using Kerio PF 2.1.4 final with proxo 4.3 and am having no problems as mentioned above. I'm running XP Pro and Win2k Pro, with Opera 6.03.
I am, however, not using any of the new commands.
|David Gallagher
|dave at smokeajay.co.uk
dave
Naoko 4.3
« Reply #32 on: June 12, 2002, 03:32:23 PM »
Same here since i didn't touch $LOG anymore.
However, i got a response from Kerio.
They are looking into it
Bes
Naoko 4.3
« Reply #33 on: June 12, 2002, 05:34:31 PM »
That's great to hear, at least, there still are some
companies who DO listen to their customers, and then there's
Scott. There *IS* still hope
Naoko 4.3
« Reply #34 on: June 12, 2002, 11:03:06 PM »
Anyone having the page loading problems - first, does it happen with the default filters?  Also what OS are browser are you using?   It's not possible for an application to read data "too fast" or "too slow" - usually the only thing that can cause a half loaded page is either network problems or the remote server not sending the full page. It's also possible some filters may be working differently then before. That's why I ask that you check anything with very large bounds since these tend to be the slowest and most problematic filters to use.
Unfortunately many people are using configs that do all kinds of unusual things, and all I can vouch for is the default set.  It's possible some unusual odd syntax in a filter worked (or at least was ignored) in previous version that may cause trouble now.
ridgydidge
  • Guest
Naoko 4.3
« Reply #35 on: June 13, 2002, 08:29:51 AM »
The page not loading problem
I did as you suggested and loaded the default.cfg that comes with 4.3 - no page complete problem - all pages loaded fully
back to my preferred set JD500.cfg and the problem reoccurs
What a pity, JD's config rocks.
Naoko 4.3
« Reply #36 on: June 13, 2002, 10:05:05 AM »
Yikes! That sucks. Can you give me some url's to test?
MorpheusDreamlord
Naoko 4.3
« Reply #37 on: June 13, 2002, 04:29:09 PM »
I seem to have had more then a few crashes lately, (and one major crash-to-reboot !!), not necessarily Proxo caused, but now I'm back on 4.2, I'm running solid, and with the same filter sets. I did alter start and end .js's, but that shouldn't do too much, should it? (cpu % is up a bit, and the log window lists a little slower, but I can live with that..)
Sorry, Scott - I'll wait for 4.3.1 heheh
(Quote - 'It's not possible for an application to read data "too fast" or "too slow"' - - yup. I understand that, I was really just trying to describe what it looked like this end.)
Edited by - MorpheusDreamlord on 13 Jun 2002  17:34:48
Naoko 4.3
« Reply #38 on: June 13, 2002, 05:04:04 PM »
Remember unless someone can narrow the problems down it probably won't be fixed in a newer versions either.  BSOD type crashes can probably never be fixed my me since   they'd be driver related.
As for the half-loading, if someone can find an example of which filter may be causing it that would help.  As I've said, I've never seen this happen, but I only use my own filters. One guess, maybe a filter is trying to stuff to much into a multi-match replace in some cases? It might cause the replace output to be truncated.
Naoko 4.3
« Reply #39 on: June 13, 2002, 05:11:49 PM »
I can't find out what filter is causing the pages to be aborted prematurely, it does only seem to happen on large pages, such as bulletin boards like this (but also vBulletin boards, and boards using the UBB code), or Yahoo Groups. The thing is, since it is not easily reproducable (reloading page where this happened will load the entire page), I'd have to keep the log window open all the time, and this I'd rather do not (it ups my CPU usage a lot).
Also... the pages are not half-loading (it is not similar to the problems I had with half loading images in older Opera versions). They seem to break at a random point, for example I had it in a thread on this forum about an hour ago: the pages stopped loading on the 'All Forums' link above. After that, the content which Prox adds on <end> was added. This would seem to indicate Prox thinks the page is completely loaded...
A thought, could this have to do with Pipelining? I noticed it in Opera, Mozilla, and MSIE.
As for the BSOD's: the issue definately is in Kerio (at least on my system). Haven't had a lockup since I deinstalled it.
Edited by - Jor on 13 Jun 2002  18:17:11
MorpheusDreamlord
Naoko 4.3
« Reply #40 on: June 13, 2002, 05:28:01 PM »
Back on Proxo4.3..
http://www.webknacks.com/aptest_c2.htm
Is a popup test site. The page says
'There is a very stubborn popup on this page...
Some programs can get into a loop on this test.'
Sometimes the page hangs for 5 secs showing
'Ther'
then loads.
Sometimes the page loads fully-cut at the 'Ther' bit
A refresh fixes it, but the </html> at the end is there!!!
Doing nothing but testing this at the moment - been testing various filters for 3 hours now!!
Other than that, Jor's right - it seems to be random, NEVER happens when the dbug is on, a refresh will fix (sometime not on 1st refresh tho)
And the Log shows (some bypasses and closes removed for space)(not the flush errors - what's that?)
BlockList 58: in MIME-List, line 28
+++CLOSE 58+++
Match 57: Java redirects to links
<end> 57: Kill event handlers
<end> 57: Java @ End
+++CLOSE 57+++
<start> 59: Java @ Start
<start> 59: Kill window manipulation
<start> 59: Kill java functions
+++CLOSE 60+++
+++CLOSE 61+++
+++CLOSE 62+++
+++CLOSE 63+++
Browser reload detected...
<start> 64: Java @ Start
<start> 64: Kill window manipulation
<start> 64: Kill java functions
<end> 59: Kill event handlers
<end> 59: Java @ End
+++CLOSE 59+++
<end> 64: Kill event handlers
<end> 64: Java @ End
+++CLOSE 64+++
<start> 78: Java @ Start
<start> 78: Kill window manipulation
<start> 78: Kill java functions
<end> 78: Kill event handlers
<end> 78: Java @ End
+++CLOSE 78+++
BlockList 86: in Bypass, line 20
** 86 Socket Error 10038 for request flush **
+++CLOSE 83+++
BlockList 87: in Bypass, line 20
+++CLOSE 91+++
BlockList 92: in Bypass, line 20
** 92 Socket Error 10038 for request flush **
BlockList 93: in Bypass, line 20
<start> 171: Java @ Start
<start> 171: Kill window manipulation
<start> 171: Kill java functions
<end> 171: Kill event handlers
<end> 171: Java @ End
Edited by - MorpheusDreamlord on 13 Jun 2002  18:31:05
Edited by - MorpheusDreamlord on 13 Jun 2002  18:50:17
Naoko 4.3
« Reply #41 on: June 13, 2002, 06:07:18 PM »
hi morpheus and scott.
i've tryed the link provided above and no pup-up appeared but when i tryed to access to the domain i experienced a system block and had to reboot. this happened 3-4 times in the last 2 days with naoko 4.3, win me, ie 5.5 in different web page in a random way. i'm sure that i haven't software conflict because i have recently formatted my system and still not have the time to install the rest of the software.
i'm not using the new proxo commands, byte limit is under 16000 in each filter and never had problem with naoko 4.2, that i used until yesterday with the same filter set. note also that i have this forum in the bypass list and yesterday it happened a system block also here!
if i will be able to reproduce the problem i'll post here the step to follow.
Naoko 4.3
« Reply #42 on: June 13, 2002, 06:10:04 PM »
on my second attempt to http://www.webknacks.com/ all works fine..
MorpheusDreamlord
Naoko 4.3
« Reply #43 on: June 13, 2002, 06:15:47 PM »
SCOTT!!
Please check Proxo43, please...  I just had a major ifshlp.sys bsod, just after restarting prox43 and going to webnacks again
(that popup page is a great test).
http://www.webknacks.com/aptest_c1.htm
This has never happened under 42, and all other settings (explorer, IE, etc) are the same as last month, and so on back.
I truly have had a lot more system errors after using 43 than 42 (to be honest I have had some errors before 43, but not this many, and so severe - usually they are of the 'unstable, but recoverable' error... now they are 'no bsod, just reboot' type.
Naoko 4.3
« Reply #44 on: June 13, 2002, 06:50:30 PM »
same here, bsod on aptest_c1 (the previous, with no problem was aptest_c2). i've pressed a key and bsod disappered but every attempt to click a link or reach a site from the address bar failed. i've received only "site unavailable" messages, the same yesterday after another bsod.
