Author Topic: Naoko 4.3  (Read 23031 times)
    • ICQ Messenger - 21893433
Naoko 4.3
« Reply #75 on: June 15, 2002, 09:23:18 PM »
I usually keep the log window open (I love the new logging options, now if you could find a way to automatically write it to a text file?)
eheh $ADDLST(LOGfile,[$DTM(d T)] | | u | )
JarC
Edited by - TEggHead on 15 Jun 2002  22:24:58
MorpheusDreamlord
Naoko 4.3
« Reply #76 on: June 16, 2002, 05:25:44 AM »
Jor, correct me if I'm wrong here, but <start> is a singular match, Proxo shouldn't go looking for more <start>s, so $STOP() wouldn't be needed..
same with <end>  ??
Come to the Dreaming...
Naoko 4.3
« Reply #77 on: June 16, 2002, 11:22:45 AM »
yes,
i've asked this exact question to scott at computer cops and both tegghead and scott have answered this.
after their answers i've wrote it in my tutorial, now updated in the p-faq section.
Naoko 4.3
« Reply #78 on: June 16, 2002, 11:28:37 AM »
In my case, I wasn't using $STOP(). Maybe the size of the CSS? I can insert another smaller css file without problems, but the main one causes problems..
Naoko 4.3
« Reply #79 on: June 16, 2002, 12:32:48 PM »
Scratch that idea..(size) I was just testing a filter at alto's page.
http://virgolamobile.50megs.com/proxomitron.html
And the half-loaded problem occurred.. So, I disabled the other filter that inserts a css & again the problem went away. I tried setting the connection timeout between 1 - 60, but it had no effect. Just for fun, I changed the match from <start> to <end> and... it worked. LoL
I doubt this helps any, but what the heck.
Naoko 4.3
« Reply #80 on: June 16, 2002, 12:53:55 PM »
hi jd, i've read your filter set,
why don't you insert the stylesheet in a more common way?
Match = "</head>|(<body)1$SET(2=<head>)"
Replace = "2"
          "<your stylesheet here>"
          "</head>"
          "1"
          "$STOP()"
MorpheusDreamlord
Naoko 4.3
« Reply #81 on: June 16, 2002, 03:53:35 PM »
Does the css atill work when it's at the end?????????
Naoko 4.3
« Reply #82 on: June 16, 2002, 04:12:02 PM »
Just at tip to everyone. It is very rare one have to use the CODE tag here. By not using the CODE tag it is also much easier to copy filters, as the CRs are preserved. The CODE tag is equivalent to HTML tag: PRE and that is also why it also sometimes makes the screen picture go outside the right side of the screen (left-right scrollbar).
MorpheusDreamlord
Naoko 4.3
« Reply #83 on: June 16, 2002, 04:38:39 PM »
I've been playing around with the 1/2 loading bug-thingy..
It happened to me on this page, ok. I reloaded - the page reloaded very fast (like from the cache), EVEN thought I did a shift-reload (IE force reload).
Still blank. Repeated shift-reload, repeat, repeat, still blank.
Empty cache and history (I always do both together..), reload. Page is fine, perfect even.
Is Proxo telling the browser to ignore the force-reload? Maybe the browser expects to find the page all in cache, and it's not all there....
(or am i talking outta my rear again...?)
Edited by - MorpheusDreamlord on 16 Jun 2002  17:41:22
Naoko 4.3
« Reply #84 on: June 16, 2002, 07:36:53 PM »
Sounds like you're version of IE still has the Last-Modified: cache bug. I removed the work-around Proxomitron had for that since it was causing other problems.
If you're still using the WinME base install, you should probably do a windows update and get your system patched up.
Naoko 4.3
« Reply #85 on: June 17, 2002, 12:15:54 AM »
I have never had this problem with half pages loaded. Tonight I started to use the ADDLST command to write to a file in 3 filters. Then the half-page problem started to come about every 4-5 reload.
Removing the "write to file" immediately fixed the problem.
Naoko 4.3
« Reply #86 on: June 17, 2002, 12:21:22 AM »
Looking in the file it writes to, it could be assumed it has to do with 2 filters trying to write to the file at the same time. In any case it can look like the frequecy of ½ pages is the same as the feequency 2 of the filters which write to the same file kicked in at the same time. maybe a coincidence, maybe not. When I wake up I will try to diable one of them to see if the ½ page comes when this collision does not occur.
Added: I had to try this before I went to bed. And it is not related to 2 filters writing at the same time. Having only one filter that can write to the file is enough for this to randomly happen.
using IE6 & W98 all patches installed.
Naoko 4.3
« Reply #87 on: June 17, 2002, 02:29:51 AM »
Don't know if it's of any relevance. Using $ADDLST logging since 12hours with 10 filters. XP, IE6, Kerio, persistant connections at 60s. No problems so far.
sidki
Naoko 4.3
« Reply #88 on: June 17, 2002, 04:56:03 AM »
Keep in mind ADDLST isn't for logging - using it that way isn't something I can recommend. You're also adding entries in memory and if you're not careful about what you add you, may get error when it tries to parse the input as a match.
Arne: ADDLST does locking so only one entry can write to the file at a time.  Not sure how it could cause a half-loaded page though.  What do the filters look like where you're using it?
Naoko 4.3
« Reply #89 on: June 17, 2002, 06:11:13 AM »
Scott: I had it in "kill offsite images" which was occurded every time on the prox-list page, together with "kill cgi banners" which, as you know occur every now and then.
Not a big deal, because I am not going to use it on filters that occur every time though. I was planning on using it in filters which I suspect very seldom kick in.
