Author Topic: Viewer for $ADDLST logs?  (Read 6907 times)
« on: June 16, 2002, 07:20:54 PM »
Hi all,
I'm setting up my filters to use this terrific new $ADDLST command,
so that they write any matches to a logfile.
This works great and looks like this:
[2002-6-16 14:58:41] HDR CT_plain text/plain http://developer.apple.com/internet/javascript/internetdev-sniffer.txt
[2002-6-16 19:35:40] WEB Banner Add Me! http://66.31.61.166/flogviewer/mainmenu.asp
[2002-6-16 20:04:01] WEB Flash "img/movie.swf" http://www.esecurity.co.kr/html_eng/products/es_ms_02.htm
Now i wonder whether someone knows a log viewer, that can do column sorting,
so that i can see for instance which filters are never triggered, which sites are most aggressive, ...
regards, sidki
« Reply #1 on: June 16, 2002, 08:40:39 PM »
I think it would be easier if you inserted som kind of a delimiter like a comma, tab or semicolon between the fields. Now it is only one long string for each input, which is difficult to separate.
dave1006
    • ICQ Messenger - 92066376
« Reply #2 on: June 16, 2002, 09:15:23 PM »
I think whitespace can be used as a seperator.
As for this function of recording 'hits', i've always felt this would be a great feature within Proxomitron, if it were added. Just a little counter for each filter with a start date - so you can see hits (total/per day etc).
|David Gallagher
|dave at smokeajay.co.uk
dave
« Reply #3 on: June 16, 2002, 09:17:10 PM »
You are right Arne. For now i inserted a tab since it's easier for manual reading.
« Reply #4 on: June 16, 2002, 09:21:22 PM »
About whitespaces. They could be used, but in this case there are a bit too many of them:
...] WEB Banner Add Me! http.......
So one of the other will be easier to deal with.
And when it is delimited, one can even copy paste directly into a spread sheet and sort it there, if you don't have a flat database viewer program.
« Reply #5 on: June 16, 2002, 09:23:05 PM »
Didn't see you post Dave. The $ADDLST command can also just count hits
sidki
dave1006
« Reply #6 on: June 16, 2002, 09:30:30 PM »
hi,
yeah Arne using a seperator is the simplest way, but you can use whitespace, as we know the first two 'tokens' are the date, and the last token is the link, so using a tiny bit of math you could count all other tokens as the filter name match :)
hi sidki,
Does the list count up though, or just log a certain number of entries?
And yeah, I think the addlist feature is very useful for logging etc, but personaly i'd still like a tiny counter within proxo itself :)
If there was a wishlist, that'd be my 'thing' :)
|David Gallagher
dave
« Reply #7 on: June 16, 2002, 09:37:27 PM »
The list would grow one byte on every hit, so you'd see it by the filesize.
Not so comfortable as a real counter i admit.
dave1006
« Reply #8 on: June 16, 2002, 09:47:20 PM »
I spose you could use windows explorer and set the 'order by' to filesize' and, presuming you have a list/file for each filter,by filter name, you'd then see the filters names in order of 'hits' :)
|David Gallagher
dave
« Reply #9 on: June 16, 2002, 10:13:56 PM »
Just realized: The only two things missing to create a CLF log with proxo is catching the outgoing HTTP commands (GET, POST, ...) and the incoming HTTP/1.x lines.
« Reply #10 on: June 16, 2002, 10:35:11 PM »
I found a viewer
It's not very pretty and accepts only tabs and commas as delimiter, but it does its job (column sorting, nothing more). Kiwi Logfile Viewer:
http://www.kiwisyslog.com/software_downloads.htm
BTW, i use their syslog daemon (for firewall and NT log messages). It's quite nice.
sidki
« Reply #11 on: June 16, 2002, 10:52:37 PM »
Could you post an example filter that writes to this file, so that others can see how you put the date and other info in there.?
« Reply #12 on: June 16, 2002, 10:58:12 PM »
Sure
[Blocklists]
List.LOGfile = "..Log.txt"
Name = "Kill: Flash animations (no ACR)"
URL = "($TYPE(htm)|$TYPE(js))"
Bounds = "<object*</object>|<embed*>( </embed>|)"
Limit = 1024
Match = "[^>]++(codebase|type)=$AV(*(flash|shockwave)*)*"
        "&(*<param ( name=$AV(movie|src)| value=$AVQ(1))+{2}|*src=$AVQ(1))"
        "&$ADDLST(LOGfile,[$DTM(d T)]   WEB Flash   1    u)"
Replace = "<span class=prox style=display:none;><a href=1 target="_top">[flash]</a></span>"
sidki
« Reply #13 on: June 16, 2002, 11:15:58 PM »
Thanks, I wa thinking of adding something to the P-FAQ tomorrow, and then it was nice to have something with the date and Tab in it as well
« Reply #14 on: June 17, 2002, 05:01:14 AM »
Please - ADDLST should not be used as a make-shift log file.  It's very likely to cause problems and eat up memory. Remember, it's parsing everything you give it as a matching command.
