Author Topic: Strip Pre-HTML JavaScripts  (Read 3936 times)
« on: July 05, 2002, 04:38:34 PM »
Hi all,
This one is a pendant to Scott's Post-HTML JS filter:
Name = "Remove: Pre-HTML JavaScripts"
URL = "$TYPE(htm)(^$LST(Bypass_Ads))"
Bounds = "<script*</script>*<html>"
Limit = 1024
Match = "(#<script$INEST(<script,</script>)</script>)+#"
Replace = "@
<span class=prox style=display:none;>[PreScript killed]</span>$STOP()"
or without CSS and a Bypass Ads list:
Replace = "@
[PreScript killed]$STOP()"
I haven't seen any ill effects yet but maybe i just missed the problematic sites .
edit: Bounds updated.
regards, sidki
Edited by - sidki3003 on 05 Jul 2002  22:18:54
« Reply #1 on: July 20, 2002, 04:30:21 PM »
Updated, matches more often now.
Name = "Remove: Pre-HTML JavaScripts (FBI)"
Bounds = "<script*</script*>*<html*>"
Match = "(#$NEST(<script,</script*>))+#"
Replace = "@
<span class=prox style=display:inline;>[PreScript killed]</span>$STOP()"
sidki
« Reply #2 on: August 04, 2002, 03:19:47 PM »
hi all,
i've modified the sidki filter "Remove Pre-HTML JavaScripts" as follow:
Name = "Remove Pre-HTML JavaScripts"
Bounds = "*<html*>"
Replace = "@$STOP()"
this way the filter always matches, then always stops and will not be checked for the rest of page.
previous version of bounds did it match every time the <script> tag was encountered, but if it was not before the <html> tag the filter not stopped and its bounds continued to be checked for every <script> in the page.
also, modifying the bounds and making the filter always match, we have to renounce to the info [PreScript killed], but who cares ;)
if you apply this modify, you can also remove the line:
<!doctype*>$SET(1=)
from my managedtags.txt list, because everything is not a script before the <html> tag will be preserved by the new version of "Remove Pre-HTML JavaScripts".
this causes also a little improvement in filtering speed because every time the managedtags.txt list is scanned there will be a line in less to check.
NOTE: you have to place "Remove Pre-HTML JavaScripts" as your FIRST web filter following the ones matching <start>. For this filter that is the optimal position because it will match as soon as possible then it will be disabled.
let me know your comments and suggestions,
« Reply #3 on: August 14, 2002, 09:00:51 PM »
Altosax,
I like the idea of *<html*> bounds and use it in my current set (link below).
I don't like to protect the whole Pre-HTML code, since there can be more than scripts that's worth being filtered.
I leave this thread as is, since the filter is harmless and tested for quite a long while.
The successor is here, it's not harmless .
... we have to renounce to the info [PreScript killed], but who cares ;)
Me
Edited by - sidki3003 on 19 Aug 2002  17:17:56
